Old 07-04-11, 09:38 PM   #11
Sly
Default Re: THAT left handed threaded engine bolt
Originally Posted by muzikill View Post
Ive got THAT left handed bolt to tighten
Please pardon my ignorance, but which bolt is that? I haven't had my engine apart yet. Always good to be aware of left-handed threads before damaging tools and sinews trying to turn them the wrong way
Old 08-04-11, 08:53 PM   #12
muzikill
muzikill's Avatar
Crankshaft bolt that also holds in the rear camchain & the water pump gearing, it has 'L' on the head and you only take it off if you have a major repair to make.
Old 08-04-11, 09:06 PM   #13
Sly
Thanks. I hope I never have cause to meet it
Left handed drill bits? Teejayexc Idle Banter 33 27-12-12 08:24 PM
Oil sump bolt, turn left or right MiniMac SV Talk, Tuning & Tweaking 11 07-05-08 03:54 PM
Left or right handed? Ed Idle Banter 42 14-12-07 01:45 AM
Engine bolt seandixie Stuff Wanted 1 15-07-06 10:11 PM
Left Handed Bike? Yarodia Idle Banter 44 18-04-06 08:51 PM
