Old 07-05-08, 12:18 PM   #1
MiniMac
Default Oil sump bolt, turn left or right
To get it off? Seems to be on REALLY tight.
So, sitting on the bike, turn to left or right?
MiniMac is offline   Reply With Quote
Old 07-05-08, 12:23 PM   #2
blueto
Default Re: Oil sump bolt, turn left or right
righty tighty as they say
Old 07-05-08, 12:24 PM   #3
Stig
It's a clockwise thread as all the rest of the bolts on the bike. Turn it anti-clockwise as looking from underneath to undo.
Old 07-05-08, 12:25 PM   #4
Grinch
If you do get it off, check the thread on it and maybe even get the copper washer replace, incase someone has over done it.
Old 07-05-08, 12:56 PM   #5
Lefty loosey, righty tighty (with just a couple of exceptions on the SV, and one of those is inside the engine and safely hidden) But it's really, really easy to get this the wrong way round when working at odd angles, I like to use a ratchet on this sort of location so I can set the direction first then there's no risk of messing up.
Old 07-05-08, 01:08 PM   #6
MiniMac
Yeah, once I got the 6tooth socket rather than 12 it was a easy task.
Need to get a filter wrench though, I can't get it off. Put a screwdriver through it, but it won't budge.
Old 07-05-08, 01:13 PM   #7
Stig
Get a longer screwdriver and punch all the way through and back out again. You can then use the filter as a lever against it's self as leverage.
Old 07-05-08, 01:32 PM   #8
Grinch
I do the same... who did your servicing last time as it sound like they rammed everything on over tight.
Old 07-05-08, 01:43 PM   #9
MiniMac
A dealership near St Helens,
I've only been riding it a few weeks, I'll be doing most of my own servicing. Once I've got all my daft questions out the way, I'm quite good. Know my way around a car engine so time to move to bikes too
Have sourced a feck off screwdriver, so I'll get that through and see. Halfrauds is open till 8 anyway. Won't be able to make the Scotch Piper tonight though
Old 07-05-08, 03:19 PM   #10
Stig
I never have to use anything to get my filter off other than a bit of elbow grease.
Sump plug bolt Jimbo_Bimbo SV Talk, Tuning & Tweaking 28 04-09-08 12:42 AM
how to get the sump plug/bolt or filter bolt out without murdering someone? Paul the 6th Bikes - Talk & Issues 11 31-05-08 10:49 AM
Dump sump/ Drain bolt malongworth Stuff Wanted 2 13-05-08 02:32 PM
oil sump bolt washer lukemillar SV Talk, Tuning & Tweaking 8 13-09-06 10:22 PM
Oil Sump Bolt BazJ27 SV Talk, Tuning & Tweaking 2 19-08-06 10:14 AM
