Old 30-05-08, 06:10 PM   #1
Paul the 6th
Paul the 6th's Avatar
Default how to get the sump plug/bolt or filter bolt out without murdering someone?
further to my last thread here: http://forums.sv650.org/showpost.php...9&postcount=16
i can't seem to get the sump plug bolt or filter nut loose. They won't budge and I've broken about 4 tools whilst attempting to get these feckers out. Does anyone have any good tips for getting these out before I murder someone (probably the bast who designed these fixings)...
ta pt6
Old 30-05-08, 06:26 PM   #2
leatherpatches
Default Re: how to get the sump plug/bolt or filter bolt out without murdering someone?
IIRC there's a filter nut tool (but I might be wrong).
I'd try both with a warm engine, to be honest. Better changing the oil that way, too.
Old 30-05-08, 07:00 PM   #3
they SHOULD'NT be that tight? who did the last service?
Old 30-05-08, 07:20 PM   #4
leatherpatches
Turning the right way I hope!
Old 30-05-08, 07:22 PM   #5
Toby
righty tighty lefty loosey!
Old 30-05-08, 10:58 PM   #6
GMS
GMS's Avatar
Did you sort this Paul ? Ive got a filter removal tool ( large socket that fits the end of the filter to turn it ) if you need to borrow it text me in the morning and I can pop it over for you. I`l PM my mob. number to you.
Graham
Old 30-05-08, 11:01 PM   #7
Paul the 6th
In the end I fecked it off and went to see sex in the city movie. I remember the mantra righty tighty lefty loosey but completely disengaged the conversion when it comes to upside down bolts Think I might have been trying to tighten them up for an hour or so...
luckily the sump bolt didn't rotate at all, the oil filter turned about half a turn so we'll have to see. I'll give you a shout if i get stuck graham - thanks in advance!
Old 30-05-08, 11:04 PM   #8
ThEGr33k
Mine was a bitch on the prilla. Must be some people love to over tighten them so no oil EVER comes out... Sigh. Just pull and pull as hard as you can untill it lets go all of a sudden and you skin your knuckles. Thats what I did.
Old 31-05-08, 05:25 AM   #9
leatherpatches
I did wonder if you were having that much trouble. I hope you haven't caused any mischief by tightening it up too much.
Now for the important question: why the hell did you watch SITC? Horrible girly flick that it is!
Old 31-05-08, 07:53 AM   #10
Flamin_Squirrel
Do you have a ratchet? Always the best tool to use in these situations, as you can check whether it's set to do up/undo before you get under the bike.
Sump plug bolt Jimbo_Bimbo SV Talk, Tuning & Tweaking 28 04-09-08 12:42 AM
Dump sump/ Drain bolt malongworth Stuff Wanted 2 13-05-08 02:32 PM
Oil sump bolt, turn left or right MiniMac SV Talk, Tuning & Tweaking 11 07-05-08 03:54 PM
oil sump bolt washer lukemillar SV Talk, Tuning & Tweaking 8 13-09-06 10:22 PM
Oil Sump Bolt BazJ27 SV Talk, Tuning & Tweaking 2 19-08-06 10:14 AM
