Old 11-04-11, 06:31 PM   #11
Owenski
Default Re: Clutch no engaging
Is that WD installed correctly? The spring looks to be going down on your pic, its been a while since I've been in that area of an SV but IIRC I thought the spring went up and hooked onto the clutch cable connector.
If thats the case then perhaps you popped it all back together back to front.
*he states, wildly stabbing around in the dark*
Old 11-04-11, 07:01 PM   #12
650sv
Yeah thats the same as the picture in the haynes manual
Old 11-04-11, 07:14 PM   #13
Fade
Looks like you've got plenty of movement, you should be able to move the rest of the plates when the plate lifts up, if they are all stuck together then that's your problem.
Either force them apart or you could put the bike up on a paddock stand and warm the engine up, that should help free them.
Old 11-04-11, 07:26 PM   #14
650sv
Default Re: Clutch not disengaging.
Well the cover is off now so I will wait untill morning and take the plates out to soak them.
Thanks for the help so far guys!
Old 11-04-11, 07:49 PM   #15
mikerj
Yes that looks absolutely fine. Now you have it that far apart you might as well split the clutch and check the plates out. I suspect you'll find one or more of the steel plates are stuck to the friction plates.
Old 12-04-11, 03:03 PM   #16
650sv
right so just put the clutch back together after letting the plates soak all morning and what do you know. It works!! For some reason now though it is hesitating to select first gear, could this be connected??
Old 12-04-11, 03:09 PM   #17
rictus01
rictus01's Avatar
adjustment will have changed, so reset that, then check the normal stuff, chain adjustment, oil level, selector shaft lubrication, you know that kind of thing.
Cheers Mark.
Clutch not disengaging? Deano24 SV Talk, Tuning & Tweaking 5 06-11-10 05:23 PM
Clutch not disengaging Jamie_SV SV Talk, Tuning & Tweaking 5 04-04-09 06:57 PM
First Gear Not Fully Disengaging tristdac SV Talk, Tuning & Tweaking 14 31-12-07 04:14 PM
Clutch Not Fully Disengaging mosius SV Talk, Tuning & Tweaking 1 25-08-07 06:24 AM
Clutch not disengaging. Mesomorphman SV Talk, Tuning & Tweaking 22 19-09-06 09:40 PM
