Old 13-04-11, 06:35 PM   #11
Default Re: Fitting a ZX10 06 shock to a Curvy
well from the picture that mr smith sent me i made it so his battery would be in the same position as was in the picture.
soooooo, the box goes on the main rear subframe diagonal bars with the rails of the box (the ones with the holes drilled in them) resting on the main rails of the rear subframe. the opening of the box goes towards the back of the bike and the battery goes front or back side down inside the tray (depending on how long the battery connections are). the picture he sent me had the battery sitting horizontal in front of the tank between the main upper subframe rails.
take the tray and stand it up (rails with holes vertical) then put the battery in the tray then lie the tray on its back (rails with holes now horizontal) then all will become apparent.
Old 13-04-11, 07:08 PM   #12
Berlin
Ok,
...Its a very nice box!
C
Old 13-04-11, 07:15 PM   #13
Rofl.....
Old 13-04-11, 09:03 PM   #14
Originally Posted by Berlin View Post
Ok,
C
Rofl.....
Bib the Spanner thing is apt! Been a grade A* premium plonker.
Anyways the bikes fine, the settings B dialled in off the bounce test
Old 13-04-11, 09:09 PM   #15
dont put yourself down m8. at the end of the day its all just sizz and giggles.
if we never made mistakes we would not learn anything.
but yes you are a spanner rofl.
runs and hides
Old 13-04-11, 09:10 PM   #16
its alright mate. I know i am this time
How you think this thread came around!
Old 14-04-11, 04:50 PM   #17
Chandler93
So from this, I'm presuming that it's just a straight-swap with the standard SV shock? Plus the removal of the battery cover?
Mines a K3s model so is there any difference from the K6n used on the SVrider forum guide?
Also how well would the ZX10 spring work with my 14 stone (88kg) weight? And how would it cope with the addition of a full top-box and panniers?
Thanks, Mike.
P.S. I'm pretty crap at this sort of stuff so I prefer to just ask and learn!
Old 14-04-11, 05:05 PM   #18
ask away m8. but i would suggest that you start a new thread unless that is its ok with andy a berlin.
if you have a dig around the forum there is tons of knowledge on the exact subject.
but in a short condensed answer:
yes its the same as the svrider guide
there is a website that tells you all the spring rates..
Old 14-04-11, 05:23 PM   #19
Mr Speirs
Mr Speirs's Avatar
The ZX10R shock would do well with your weight but make sure you buy the right year. 06-07 is right but 04-05 is wrong. You can identify them by the angle resivour on the shock. If it is 90 degrees from the shock you have the correct 06-07 shock if it is more a 45 degree upwards angle that's too old. Both shocks are gold with a red spring.
Old 14-04-11, 05:29 PM   #20
Chandler93
Cheers! I thought it would be easier just to keep it in one thread so there isn't more being posted about the same old stuff =P
Right, i'll look out for that!
Found a good condition one on ebay for £100 so i'll just keep an eye out in the next month or so to see if one pops up cheaper!
ZX10 shock fitting problem. sprocket SV Talk, Tuning & Tweaking 26 10-03-10 09:09 AM
ZX10 Shock on a Curvy TheShadow SV Talk, Tuning & Tweaking 27 15-06-09 10:33 PM
ZX10 rear shock advice [yet again] tonny006 SV Talk, Tuning & Tweaking 7 22-09-08 04:49 PM
zx10 shock skapegoat SV Talk, Tuning & Tweaking 10 20-01-08 10:02 AM
ZX10-R '04 Rear Shock - Curvy Upgrade pmapp For Sale - SV's and SV related items 5 01-10-07 09:02 AM
