Old 23-08-11, 10:05 PM   #11
mikerj
Default Re: Textile Panniers
Yes, I bought the Kreiga US40 set (US20 + 2x US10) when I went to the IOM on my RSV this year. Properly good quality kit with a fully waterproof liner and hold a surprising amount of stuff. The US20 bag comes with a shoulder strap so you can use it as a general purpose bag for carrying stuff around which I found pretty useful, though would have been better with two straps like a back pack. They can be fitted in any combination e.g. US20 by itself, US20 + one US10 or with both US10's, and the US20 is easily big enough for a few days worth of stuff by itself.
They fit by straps passing under the pillion seat so they are very quick and easy to fit and remove once you've done it a couple of times. Only problem I found is that no matter how tight I pulled the straps they gradually moved forward and ended up pressing against my backside which was annoying. They do have a sort of anti-slip mesh built into the bottom, but it wasn't particularly grippy so will use some of the really grippy stuff you get with tank bags next time.
Overall I was impressed and can recommend them. The sliding around my well have been peculiar to the RSV seat as I've not heard any other complaints, but I think it's easily fixed anyway.
Old 23-08-11, 10:09 PM   #12
mikerj
Originally Posted by Tommy H View Post
Dunno if any panniers come with it, but you can get matts that stop the rubbing, or use blue foam etc. Like I said - lesson learned.
FWIW I used a sheet of self adhesive clear plastic that is especially meant for protecting paintwork. It was difficult to fit to the compound curves of the tail bodywork so it's didn't look particularly great but there is no way the paint can get damaged unless a strap rubs all the way through the plastic and I took it off after the trip anyway. The grippy matts are ok, but it's easy to trap grit against the paint unless you make sure it's scrupulously clean.
Old 25-08-11, 06:21 PM   #13
ImplodedHamster
i did 3 days on a oxford tank bag, which is fantastic for longer, i would just add a tail pack (Kreiga are meant to be v. good) or/and some oxford panniers
hth
Old 30-08-11, 09:19 PM   #14
mpsricky
thanks everyone, won a bid on ebay for oxford first time panniers. Was looking at the anti slip oxford blanket and the clear film, dont know which to go for.
Old 30-08-11, 09:22 PM   #15
svian
Bike blanket everytime. Just lay on the tail unit and put the panniers on top.
Old 30-08-11, 10:01 PM   #16
littleoldman2
littleoldman2's Avatar
I use some stuff the better half (yes its true) got from her mate for lining draws, it stops your mugs rattling in the draws as well as my soft luggage moving about.
Buffalo Sports Panniers vs. Expanding Panniers (both soft) Paul the 6th Bikes - Talk & Issues 8 04-02-10 08:30 PM
Textile Trousers metalmonkey Bikes - Talk & Issues 21 30-12-08 12:37 PM
Textile Pants? nobby Riding Gear 7 25-08-08 06:16 PM
HG Textile Jacket furrybean For Sale - SV's and SV related items 0 18-01-07 07:22 PM
HG Textile Jacket furrybean For Sale - SV's and SV related items 4 13-11-06 07:39 AM
