Old 01-11-11, 11:31 AM   #11
christian1000
Default Re: Stock shock swap stuck bolt strife!
Have you put a block under the tyre so the weight of the swingarm and tyre isn't being held by the shock? That's what I forgot when I did mine and I experienced the same situation.
Old 01-11-11, 11:46 AM   #12
Taipan
Taipan's Avatar
Originally Posted by fentible View Post
Taipan: Yes, up on two speaker stands, of all things..
You still need to lift the wheel and swinging arm up as the weight of these is resting on the bolt. Can you get a trolley jack under them or someone to lift them whilst you wiggle the bolt out?
Old 01-11-11, 12:08 PM   #13
Mr Speirs
Mr Speirs's Avatar
If you are looking at the bike from the back..which side of the shock is the head of the bolt on?
Old 01-11-11, 12:26 PM   #14
fentible
Yorkie: I'll take a pic when I can next get to the bike.
Darren: I don't think I can!
Christian/Taipan: I've already undone the linkage bolt, at which point the wheel fell. I thought at that point the weight was off the shock and linkage. If not I'll wedge some more stuff under the tyre and see if I can make it easier.
Mr Speirs: It's on the left.
Thanks for all the responses.
Old 01-11-11, 01:05 PM   #15
mister c
mister c's Avatar
I did a "How to" with pics here if it helps http://forums.sv650.org/showthread.p...ighlight=shock
Old 01-11-11, 03:50 PM   #16
fentible
Mister C: Thanks for that, it confirms I'm trying to shift the right thing, at least. I feel a bit of a fool for not finding that thread on my own.
Photos as requested:
I've tried propping up the wheel and it made no difference whatsoever - there doesn't seem to be any weight on the suspension.
Old 01-11-11, 03:51 PM   #17
fentible
Agh! Apologies for the giant photos! Have to run off now but I'll edit them down in size later.
Old 01-11-11, 04:15 PM   #18
TamSV
TamSV's Avatar
And there was a nut on the end of that?
Have you tried unscrewing that bolt? (as said earlier the shock mount is threaded).
If it just turns and turns but doesn't come out then maybe the previous owner has threaded the bolt and then just stuck a nut on the end. Try putting pressure on the right side of the bolt while undoing it from the left.
You could undo the other bolt for the linkage and whip the shock and linkage out together to get a better look at it/attack it with power tools.
Old 01-11-11, 05:09 PM   #19
christian1000
My bad, of course you have otherwise you can't get to the shock bolt, silly me
Old 01-11-11, 10:55 PM   #20
If you let swingarm drop then it rests on shock or linkage and still loads that bolt up to make life hard, put a brick or something under wheel to rest it on, just high enough to take weight.
That "nut" is actually meant to be welded to shock, but meh, if it is free spinning then do thing with brick as above then apply hammer and drift. Few hits then see if it has bitten and wind out. It will move.
I would take shock and linkage out and work on whole lump in vice.
Remove stuck Allen bolt Mark_h SV Talk, Tuning & Tweaking 24 09-10-11 11:17 AM
Stuck bolt with a difference..... arcdef SV Talk, Tuning & Tweaking 10 02-10-09 04:10 PM
Stuck shock adjuster? transparent_opacity SV Talk, Tuning & Tweaking 21 27-11-08 12:17 PM
Help needed, stuck crash mushroom bolt! Ash999 SV Talk, Tuning & Tweaking 6 19-05-06 10:26 PM
Stuck caliper bolt svrash Bikes - Talk & Issues 7 24-04-06 08:30 AM
