Old 04-01-12, 11:32 PM   #11
NTECUK
NTECUK's Avatar
Default Re: Vehicle MOTs 2012
Ok have you read the info panel's on the left of the official manual?
Old 04-01-12, 11:36 PM   #12
NTECUK
NTECUK's Avatar
Originally Posted by EssexDave View Post
*HID headlights can cause dazzle if they are dirty or aimed too high so car manufacturers must fit headlamp cleaning and levelling systems. A car will fail if a mandatory headlamp cleaning or levelling system is missing, doesn't work or is obviously defective.
Vehicles fitted with aftermarket HID systems must also be fitted with properly working washer and levelling systems.
In all fairness this is slightly ambiguous...
*From link on AA's website about the CHANGES that are coming in (albeit I haven't read the whole thing properly)
Not In the official manual accessed by the VTS.
any other testers on hear??
Old 04-01-12, 11:38 PM   #13
muzikill
muzikill's Avatar
They'll just swap the bulbs over for MOT time
I expect it to become a enforceable law to stop this. Its a doddle to spot it and check what a vehicle failed on previously. Itll become one of those things the police can enforce during spot checks.
Old 04-01-12, 11:47 PM   #14
EssexDave
I'm assuming the manual is up to date with the changes from Jan 1st?
Old 04-01-12, 11:51 PM   #15
NTECUK
NTECUK's Avatar
this is the manual you access from the VTS when we log on and off an MOT and issue yor pass or fail.
so yes its the word of god.
when we fail a vechle we have a list of what we can reject ,.
so you cant make them up
See the official manual for what ever class you have
Class 5 its getting real tight
http://www.motinfo.gov.uk/htdocs/index.htm
Old 05-01-12, 12:10 AM   #16
SoulKiss
SoulKiss's Avatar
Also going to have to be careful when cutting to fit a new can...
"Exhaust
A catalytic convertor fitted as original equipment but missing will be a reason for failure."
Old 05-01-12, 12:25 AM   #17
tigersaw
tigersaw's Avatar
I've just read the motorcycle link download (thanks), I can't see any mention of a speedo in it. Can I imply the mot man does not have to see one?
Only asking as I've swapped mine for a GPS
Old 05-01-12, 08:42 AM   #18
Lozzo
"Exhaust
Not applicable to bikes
http://www.motinfo.gov.uk/htdocs/m1s07000101.htm
Old 05-01-12, 09:06 AM   #19
NTECUK
NTECUK's Avatar
It would be under Body and Structure.
So not for Bikes ...yet
Old 05-01-12, 12:18 PM   #20
SoulKiss
SoulKiss's Avatar
From that link...
"1. a. Any part of the exhaust system missing or excessivelydeteriorate"
Surely if a Cat is supposed to be there then it falls foul of this?
MOTs Fizzy Fish Bikes - Talk & Issues 13 26-09-09 03:28 PM
So this SORN thing, MOTs etc timwilky Idle Banter 3 12-05-09 12:13 PM
Plate Sizes & MOTs Demonz Bikes - Talk & Issues 4 08-05-09 05:41 AM
Manchester MOTs gettin2dizzy Pennine Massive 8 28-04-09 10:31 PM
MOTs in Sunny Essex dissuade The Essex Lounge 5 29-07-08 02:01 PM
