#11 |
When you can't get it into first, (with it running...), try momentarily release the clutch, then attempt to select 1st again.
(sometimes with the 'box stationary, the dog teeth are directly aligned and so can't slide to engage each other, this is normal. Apologies if this is teaching how to suck eggs)
#12 | ||
Also as I said my battery was dead, I went to charge it today and it says that I have to buy a new battery cause this one is way dead. So that will take a little while before I can start it up again and see if that makes a difference. Last edited by 808OR; 17-02-12 at 08:25 AM. |
#13 |
With the bike off, try shifting as you rock the bike backwards and forwards slightly, clutch out.
I do not believe you could do any damage snapping poxy bit of brittle alloy off. They snap all time and I have never seen real damage from it.
#14 |
Tried this now. It feels like I get down into first, still with some difficulty though. But Still not able to shift above neutral. When I roll it forward and get it to first and let the clutch out it stops rolling, which means it is in first, then but up to neutral and it rolls, again shifting between first and N is kind of difficult. Still can't shift up past neutral.
#15 |
Got punted up the **** and into a park car, it knocked the gear select hard while revs were high.
#16 | |
Does this work ok? |
Gearshift pattern for the SV650? | m1tch_1987 | SV Talk, Tuning & Tweaking | 13 | 30-01-12 07:02 PM |
How to change my gear lever? | musne | SV Talk, Tuning & Tweaking | 19 | 16-04-11 06:21 PM |
Gear Change Lever | xXBADGERXx | SV Talk, Tuning & Tweaking | 2 | 07-11-09 11:25 PM |
gear change lever? | arcdef | SV Talk, Tuning & Tweaking | 21 | 04-12-08 06:52 PM |
Gear change lever | Ward8124 | Bikes - Talk & Issues | 0 | 03-02-07 04:19 PM |
