Old 29-01-12, 05:55 PM   #1
m1tch_1987
Default Gearshift pattern for the SV650?
Hi all,
I am just wondering what the shift pattern is on the SV, is it 1,N,2,3,4,5,6 or N,1,2,3,4,5,6?
Just wondering!
Old 29-01-12, 05:57 PM   #2
Default Re: Shift pattern for the SV650?
one down 5 up
Old 29-01-12, 07:08 PM   #3
m1tch_1987
Thought so, im guessing its impossible to change the shift pattern?
Old 29-01-12, 07:19 PM   #4
aaron020873
i would of thought so, but out of interest why would you want to do this?
Old 29-01-12, 07:28 PM   #5
m1tch_1987
Its because I will be using it in a kart, but I guess I will just need to remember to shift twice on the way up between 1st and 2nd lol
Old 29-01-12, 07:33 PM   #6
That's not how they work.
On the bike you wouldn't shift twice would you... The ratchet moves far enough 1>2 to skip neutral, you get neutral by pushing it up from 1st a little bit, if not careful it's easy to miss and get 2nd.
Old 29-01-12, 07:41 PM   #7
AZZ3R
As YC has said, the force from 1st - 2nd you will skip neutral unless your wanting to find (N). Usually half click to Neutral.
Old 29-01-12, 07:54 PM   #8
m1tch_1987
Ah ok, thanks for the help guys, ive never ridden a bike, so am not used to the shifting etc I am correct that you can shift up without the clutch (if you let off the throttle) but need the clutch for downshifts?
Old 29-01-12, 07:58 PM   #9
Yep.
Or you can fit a quickshifter for the way up, then you don't need to back off
Old 29-01-12, 08:35 PM   #10
m1tch_1987
What does the quick shifter entail?
1x Pattern RH mirror. SVs 03+ injury_ian For Sale - SV's and SV related items 2 19-04-11 11:21 AM
Pattern mirrors - Curvy. ferret23 SV Talk, Tuning & Tweaking 8 27-04-10 08:40 PM
Reg/rec pattern part thedonal SV Talk, Tuning & Tweaking 26 12-05-08 09:43 AM
Pattern parts the oaf SV Talk, Tuning & Tweaking 3 20-07-06 11:36 AM
