Hardware Post your own reviews, opinions and experiences on this subject.
Old 25-03-12, 12:43 PM   #11
MJC-DEV
MJC-DEV's Avatar
Default Re: Tutoro Chain Oiler
Had a chance too take some pix to shown how I mounted the Auto TuToRo on my SK6
Tutorro_1 by MJC-DEV, on Flickr
Tutorro_2 by MJC-DEV, on Flickr
Tutorro_3 by MJC-DEV, on Flickr
2006 SK6, wavy discs, 8.5N K-Tech springs, Debrix Emulators, Nitron Shock, Silkolene RSF Pro 10W, Eastern Beaver H4 Dual Headlight Relay Kit, Avon Storm Ultra 2 tyres, Ebay billet brake/clutch levers
MJC-DEV is offline   Reply With Quote
Old 27-04-12, 09:09 PM   #12
Lozzo
As good as that Tuturo system might be, I just couldn't live with the fact that it is out on full view and with all pipework showing. I like my accessories to be neatly installed and hidden away as much as possible, and if on view they have to look like they were fitted at factory. There's no way you can do that with a Tutoro.
I'll stick to my Scottoiler thanks.
Old 27-04-12, 09:40 PM   #13
Jayneflakes
Jayneflakes's Avatar
We have the Auto mounted on the ZRX behind the front rider heel plate. The pipe work is just visible, but we live with it, which is a shame because the ZRX swing arm is a work of art.
The basic oiler on my SV is a little less visible, but is still to hand even when on the move.
Jayne you're a Pussy Magnet
Old 28-04-12, 08:34 AM   #14
NTECUK
NTECUK's Avatar
Fitted the basic tutoro on the RSV last night. Just enough pipework to get it next to the rad pipe bracket.
I have twin feed . I need to find an alternate fix to the ugly cable ties that hold that on place .
Old 28-04-12, 10:47 AM   #15
MJC-DEV
MJC-DEV's Avatar
Having to have the Auto Tuturo within a few degress of verticle is a bit of a limitation compared to the Scotoiler than can be almost any angle consistant with filling.
But, having done several hundres miles now it still has my vote over the Scotoiler, and is actually less noticable than it looks from my photos as it's effectively 'inside' the wheel arch. If you want a fully hidden unit then a ScotO would be hard to beat (depending on bike of course).
Old 30-04-12, 08:30 AM   #16
NTECUK
NTECUK's Avatar
For £18.00 the twin feed manual one is none to shabby .nice oil wet chain today
Old 30-04-12, 09:08 PM   #17
Dunn-y
I have my manual Tutoro fitted to the subframe right under the left hand infill. Basically un-noticeable. Will get some pics tomorrow.
Old 02-05-12, 01:57 PM   #18
Jayneflakes
Mine is fitted on the lower exposed run of the rear sub frame on the left side, it means if I have forgotten to switch it on on a long run, I can just reach down and it is right under my fingers. Does look strange if I do it on the motorway though!
My Manual has developed a slight drip from the valve that turns it on, so I contacted Tutoro and asked what I needed to do, turns out that a dab of grease will have it all sorted out and drip free again. Such a simple device and so easy to sort out if it starts to go wrong, I love mine and since buying a new chain last year at the same time as getting this, I can honestly say that my chain looks like it is still fresh out of the box.
I have seen a mod recently where some one made a fitting that did away with the zip tie fixing at the nozzle end, I am thinking about how to adapt it to fit the SV, so if I can make it work, I will show you folks here how it looks.
Old 02-05-12, 03:55 PM   #19
Thaleshwar
Hi, I am little confuse between Tutoro Auto and Scottoiller-V (not Scottoiller-E which is very expensive), as difference between 2 is hardly £10.00 or so, just that Scottoiller (V system) need the vacuum connection and Tutoro nothing. It was Tutoro original manual (retailing at £14.00 something) one that received RIDE's best buy award and not the Auto.
Old 02-05-12, 04:06 PM   #20
NTECUK
NTECUK's Avatar
I didn't think the auto was that good a buy.
It's easy to turn a knob on and off after all .
tutoro chain oiler? aaron020873 Bikes - Talk & Issues 21 16-11-11 08:32 PM
SV chain oiler embee Photos 21 30-03-11 07:29 PM
Chain oiler; do you use one? bengrrr Bikes - Talk & Issues 13 13-07-10 04:25 PM
Tutoro Chain Oiler Gabriel2k Ancillaries 19 09-06-10 05:05 PM
Chain Oiler TSM Bikes - Talk & Issues 5 17-01-05 11:18 PM
