#11 |
I weld them. Lots don't and find it works well for them.
#12 |
Don't like the way you use a plural
![]() The 4 large holes need to be drilled/reamed out. Do not drill extra ones.
2006 SK6, wavy discs, 8.5N K-Tech springs, Debrix Emulators, Nitron Shock, Silkolene RSF Pro 10W, Eastern Beaver H4 Dual Headlight Relay Kit, Avon Storm Ultra 2 tyres, Ebay billet brake/clutch levers |
#13 |
#14 |
True but somebody will fill up the main ones sometime.....
but I hope not! ![]()
#15 |
Drill/weld up whatever your happy with, its more forum hearsay than actually makes a difference, bored of arguing the point tbh.
The spring rate dictates everything else, 15wt oil is only just enough (depends on make) with .85's so on the lighter side of setup, though you still may find it a bit hard, .8's may have been more suitable |
#16 |
No argument here, with anything suspension there is more than one way to skin a cat.
#17 |
Sound. I probably wont touch the rebound holes then as I have no reliable way to close them up.
Only other thing left then I guess is what to cut the spacer with - will a hacksaw do or will I need something beefier? |
#18 |
Hacksaw is ok, the tubing isn't heavy walled.
#19 |
Thanks Chris
Going to need to buy a few bits to do this job Long Allen bit for the damper rod bolt (how long does it need to be to clear the fork leg?) Jack and/or Rope to lift the front Hacksaw + Metal files Might sound stupid but do I just cut the spacer down the thickness of the emulator? |
#20 |
Oh and I read somewhere (svriders?) that the white plastic cone bit shouldnt be reinstalled, is this correct?
Setting curvy up for rider weight - options | Dean-J | SV Talk, Tuning & Tweaking | 3 | 27-11-11 06:34 PM |
Front suspension pre-load setting | Shawthing | SV Talk, Tuning & Tweaking | 7 | 25-05-11 12:09 PM |
front brake calliper bolts torque setting | Slash | SV Talk, Tuning & Tweaking | 7 | 10-04-08 09:58 AM |
Setting The Front Cylinder Timing | HopefullySoon | SV Talk, Tuning & Tweaking | 8 | 06-11-07 03:54 PM |
Weird Supension problem | AlfBoy | SV Talk, Tuning & Tweaking | 11 | 23-12-05 03:55 AM |
