Old 21-03-12, 08:00 PM   #11
mackemforever
Default Re: Major knocking noise from engine
One more quick thing, if it is the CCT which has gone and needs replacing, am I right in thinking that you can use one from the pointy models?
I seem to recall reading somewhere that they are interchangable and that the ones used in the pointies are better quality, although I might be completely wrong here.
Old 22-03-12, 04:27 PM   #12
mackemforever
Ok, have just had the front CCT out and it seems to be working perfectly, which isn't really good news as it means that is is probably something more major.
Anybody got any ideas what I should be checking next?
Old 22-03-12, 04:35 PM   #13
flymo
flymo's Avatar
did you do the 'clutch lever fully in' test? That would eliminate the clutch/gearbox to some extent. If you are still getting horrible noises then my next step would be opening up cylinder head covers to take a look, may well be a big end bearing knackered though.
edit, make sure the CCT is refitted before attempting this!
Old 22-03-12, 05:03 PM   #14
mackemforever
I forgot to do that before taking the CCT out, however I was going to get the cover off the clutch tomorrow and check that nothing has come apart.
And don't worry, I'm going to put the CCT back in before doing anything else.
Old 23-03-12, 07:20 PM   #15
Djgary
I have a 2004 k3 naked, it's been faultless for 14 k but you've got me concerned with your comment "it's not a k3 is it" can't find anything on the web to suggest the k3 might be problematic ?
Old 27-03-12, 03:38 PM   #16
mackemforever
Default Re: Major knocking noise from engine.
Ok, I now have a few days off work and would really like to find out what the problem is before I have to go back.
My mechanical knowledge is crap, absolute crap, but I can do most jobs provided that I actually know what the job is and that the Haynes manual covers it!
So, can somebody who is more knowledgable than I am please provide me with a clear list of things to check, preferably nothing which would require me to drop the engine out of the bike.
Thank you.
Old 27-03-12, 04:23 PM   #17
flymo
flymo's Avatar
And I had a K3 race bike with 20,000 miles on it before I raced it mercilessly for three years. It never missed a beat.
Old 27-03-12, 04:24 PM   #18
flymo
flymo's Avatar
Thank you.
Where are you located? There may be somebody close by who can assist.
Old 27-03-12, 04:41 PM   #19
mackemforever
I'm in Bristol and have had help from a few people off this forum before but I want to do as much as I can myself before asking anybody else to help. I just need suggestions as to what the most likely problems could be and what I should be checking.
Old 27-03-12, 05:02 PM   #20
Fraser1200
i seem to have developed the same problem as you altho my knock only happens with the clutch out, i cant help any but will b keeping tabs on the thread to see how u get on
Finally know why i'm getting a knocking noise!! slark01 The Border Patrol 9 13-08-11 10:44 AM
knocking noise thedon1000 SV Talk, Tuning & Tweaking 22 13-10-08 08:27 PM
Knocking noise Cam_73 SV Talk, Tuning & Tweaking 3 04-08-08 07:48 PM
Knocking noise @ chain? skyline SV Talk, Tuning & Tweaking 22 07-04-08 07:40 PM
Major front end noise!!!! svrash SV Talk, Tuning & Tweaking 5 26-05-06 06:33 AM
