Old 18-05-12, 03:45 PM   #11
Rob969
Default Re: Custom Earplugs / Headphones.
Got mine today, only ordered on wednesday night. Going to make up a set of normal earplugs in the morning then have a go at a set with my headphones in
Old 18-05-12, 09:49 PM   #12
ralph
is the silicone that the earplugs are made of slightly soft or really hard as i was thinking of getting some but would have problems with hard plugs thanks
Old 18-05-12, 10:02 PM   #13
Rob969
I'll let you know tomorrow after i try them
Old 26-05-12, 08:32 PM   #14
ralph
so what were they like then? should i buy some or stick to my alpine ones
Old 12-06-12, 09:24 AM   #15
Nobbylad
Nobbylad's Avatar
I ordered 2 x sets of these and through trial and error reckon that you can get 3 x pairs of earplugs with headphones in out of 1 x box.
I initially tried using half of each compound to make each earplug, although once the headphones were inserted, a lot of the compound comes out of your ear. The 1st go wasn't a resounding success, there was more compound in the ear plug than was necessary and because I'd slightly covered the earphones once they were inserted, had a job getting them back out without damaging the rest of the earplug. Not so bad if you wanted to keep the earphones stuck in the plugs, but I wanted to be able to remove them.
I had a 2nd attempt, using less of the remaining compound (so probably about a third of the total original amount) and ensured that the earphones weren't covered. Although they were a better fit using less compound, they're still quite fragile and I really struggled to get them to sit properly in my helmet. As I put it on, it knocks them very slightly and 'unseats' them from your ear a tiny amount, but enough to not be as snug as when you wear them without your helmet.
When taking the lid off, it drags them up out of your ears and against your head which isn't the comfiest thing ever.
All in all I reckon through more trial and error I could get a near perfect fit and be able to get my lid off without too much discomfort, however not sure I want to spend much more time on it when the end result isn't that much better than using the earphones directly.
I might look about for some more 'flexible' material though, as once set, these are quite hard and I think that might be the reason for the movement/poor fit once you put your lid on.
Old 12-06-12, 11:22 AM   #16
danf1234
Have a look at Comply ear phones with foam tips. I have tried many many ear phones, including ultimate ears ones, and comply are by far the best!
Old 12-06-12, 11:57 AM   #17
Nobbylad
Nobbylad's Avatar
Did you get the earphones, or just the comply tips for existing earphones?
Old 12-06-12, 01:30 PM   #18
this stuff is just 'silly gum' and you can get it cheaper. it's used for taking moulds for cake decorating and jewellery making etc.etc
Old 12-06-12, 04:12 PM   #19
FG1
I just use bog standard Sony in ear earphones and a headover to keep them seated while putting helmet on or taking helmet off. Works with no problems so far.
Old 12-06-12, 04:15 PM   #20
FG1
Bibio, do you mean something like this:
http://www.ebay.co.uk/itm/Silly-Gum-...-/280867773904
Headphones - Again Daimo Bikes - Talk & Issues 13 14-06-10 03:38 PM
In ear headphones kellyjo Idle Banter 21 14-04-10 04:18 PM
PS3 headphones rpwoodman Idle Banter 26 11-01-10 01:12 PM
Custom Earplugs gettin2dizzy Ancillaries 12 22-06-07 11:42 PM
Headphones Blue_SV650S Bikes - Talk & Issues 31 12-04-07 03:59 PM
