Old 08-08-12, 04:29 PM   #11
Littlepeahead
Littlepeahead's Avatar
Default Re: Oil Leak Advice Please!
He's got plenty of talc, it helps him get into the gimp suit.
Old 08-08-12, 04:34 PM   #12
rictus01
rictus01's Avatar
clearly someone before has either patched up an old gasket of just not fitted one and used "instant gasket" in it's place when fitting that cover, if the oil lost is minor then I should be fine as long as you check your oil regularly, but at some point I'd get a proper gasket or make one and get that cover off, stanley knife blade to carefully cut away all that goo, and re-fit properly.
Cheers Mark.
Old 08-08-12, 04:46 PM   #13
Spank86
Ignore it and ride around with me laughing at your old leaking bike.
Old 08-08-12, 05:07 PM   #14
it's your dodgy oil and filter change abilities
Old 08-08-12, 09:40 PM   #15
Fallout
Fallout's Avatar
Actually, I didn't help it Bibio mate. Slightly overfilled. Probably put too much pressure on everything, but pretty sure it was leaking already.
@Rictus - Thanks for the advice mate. I may have a bash at the next oil change. I know spank has a proper gasket scraper he bought when he was blowing up his KTM EXC, so could borrow that and have a go refitting it.
Brake were rubbish tonight though. Think that's the priority!
MotoGoLoco - You knows it
Fallout Breakbeat (My Music)
Old 08-08-12, 09:45 PM   #16
Spank86
I'm sure that things around somewhere, I'll have a hunt next time I'm rummaging in the garage.
Old 08-08-12, 09:48 PM   #17
DJ123
DJ123's Avatar
it's because you have Orange wheels, the oil is trying to escape the horror of them
BMW F800ST
Old 08-08-12, 10:13 PM   #18
Fallout
Fallout's Avatar
Shut it Job! You go mad for my orange wheels. You want them so bad.
@Ad - Cheers dude. And what about that huge ******* torque wrench? I bet you never use that. How much did it cost you, and do you want to flog it?
Old 09-08-12, 06:55 AM   #19
Spank86
You can borrow it, but I do still use it occasionally (once a year) on the lawnmower.
If you put a pump in your undertray with a hose back up to the oil filler cap I think that'd solve the problem.
Old 09-08-12, 10:59 AM   #20
Mark_h
Mark_h's Avatar
Or just ride upside down once in a while. Maybe on the roof of the Hindhead tunnel. Some of it will drip back in.
Minister for Sustainability
Oil Leak, Need advice Serdna SV Talk, Tuning & Tweaking 9 24-08-11 06:17 PM
brake fluid leak advice please jimc SV Talk, Tuning & Tweaking 4 27-02-11 03:09 PM
advice needed RE caliper leak. arcdef SV Talk, Tuning & Tweaking 11 31-01-09 04:56 PM
Oil leak, garage at fault?? advice needed DeanoN SV Talk, Tuning & Tweaking 7 13-01-09 05:54 PM
Petrol leak update advice please Quiff Wichard SV Talk, Tuning & Tweaking 8 09-02-06 01:19 PM
