Old 14-09-12, 10:21 AM   #11
zombie
Default Re: Snapped Gear Lever Peg
Well I got the peg on. Unfortunately its a bit wonky. Poor drilling I guess.
Hopefully it won't be too noticeable riding.
Old 14-09-12, 12:14 PM   #12
Spanner Man
It looks pretty straight to me. it's the bend in the lever making it look wonky.
Looks like you have a crack in the lever near the pivot point. Unless it's a bit of crud.
Cheers.
Spanner Man
Old 14-09-12, 12:22 PM   #13
zombie
Thanks for the heads up, just checked and it wiped off so just crud.
Old 14-09-12, 05:52 PM   #14
Spanner Man
It could have been crud on my glasses. Ah The joys of knocking on a bit!
Cheers.
Spanner Man
Old 14-09-12, 09:44 PM   #15
speedyandypandy
Default Re: Snapped Gear Lever Peg - repair?
Did you use loctite on the threads? or any other thread locking fluid? The bike vibrates a bit, would be a good thing to do
Old 15-09-12, 08:35 AM   #16
zombie
Yes I put a bit of locktite on there (red tube, blue contents). Cheers.
Old 15-09-12, 01:45 PM   #17
muzikill
muzikill's Avatar
A nice trick is to wrap selfamal tape round it so its nice and grippy.
Old 07-07-13, 03:41 PM   #18
donkeybanana
Was about to fork out for some new rearsets until I found this thread, thanks!
Snapped clutch lever perch bolt. hongman SV Talk, Tuning & Tweaking 6 02-08-10 09:04 AM
Just snapped my brake lever - with my hand DarrenSV650S Bikes - Talk & Issues 15 09-05-09 05:45 PM
How to straighten a bent gear lever? (heat it up first? or what?), ---possible fix or recipe for snapped of gear lever :-) martin_SV SV Talk, Tuning & Tweaking 10 30-07-08 08:40 PM
K5 Pointy 650S right hand wing mirror, gear lever and clutch lever. Bayside GTR Stuff Wanted 0 29-10-07 11:24 PM
2 left indicators + clutch lever + gear lever for pointy k6 enduroman Stuff Wanted 3 06-09-07 09:26 PM
