Old 03-10-13, 08:57 PM   #11
rictus01
rictus01's Avatar
Default Re: Dash light bulbs (SV650s, '02)?
this thread is about the "DASH" bulbs, not headlight ones.
having said that H4 bulbs are fitment on the SV.
Old 03-10-13, 09:00 PM   #12
apchara
I know its a dash thread, its the dash bulbs I was asking about, my post was unclear, my apologies
Old 03-10-13, 09:38 PM   #13
rictus01
rictus01's Avatar
if you read post 5 in this thread it'll tell you the answer
Old 03-10-13, 09:40 PM   #14
apchara
Cheers bud, was sitting in a service station dripping wet in my kevvy jeans didnt read through properly
Old 04-10-13, 07:07 AM   #15
Mauler
Mauler's Avatar
This thread may also help, oddly also the 5th post down to start with.
"If more of us valued food and cheer and song above hoarded gold, it would be a merrier world."
-Thorin Oakenshield, The Hobbit
Mauler is offline   Reply With Quote
Old 06-10-13, 10:08 AM   #16
slug
Dash LEDs
I replaced my standard bulbs a year of so back when all the speedo lights had final gone - made nightriding a bit guesswork.
Dismantling the dash is a bit fiddly but not difficult. Remove fairing, take out the clocks and then open up the clock box.
The bulbs for both the warning lights and backlights are T509 fit on a curvy (mines a 2002 SK2). I don't know if they are the same for a pointy but I suspect so.
I found LEDs on this website www.crazyleds.co.uk
They have both LEDs built into a T509 twistfit fitting http://www.crazyleds.co.uk/509T-TWIST-LOCK-LED.html or I bought pushfit 286 T5 LEDs to go into a T509 fitting (more colour options and a wider light spread) http://www.crazyleds.co.uk/286-T5-Capless-LED.html + http://www.crazyleds.co.uk/509T-twist-lock-holder..html The LEDs are about 60p each and the fitting 27p.
Coloured LEDs behind the warning light lenses work really well and I fitted blue backlights to the speedo/rev counter.
They've been in a for about 7000mls and no sign of any hotspotting
Reassembly is reverse of stripping but be careful in reassembling the clock box so as not to trap the seal between the two bits.
Old 07-10-13, 10:46 AM   #17
DryRob
Could you put a photo up of your blue clock lights please?
DryRob is offline   Reply With Quote
Old 07-10-13, 11:14 AM   #18
Mauler
Mauler's Avatar
Check the link in my post for an example, Rob.
Old 08-10-13, 07:28 AM   #19
DryRob
Ta, very interesting thread by the way
Old 08-10-13, 07:44 PM   #20
slug
Here you go.
The clocks has wide angle blue LEDs
The warning lights also have coloured LEDs for each behind the standard lenses.
SV650s K4 LED Side Light Bulbs vardypeeps SV Talk, Tuning & Tweaking 5 02-02-13 08:36 PM
Changing dash bulbs? dazzaboy Bikes - Talk & Issues 17 05-10-12 09:29 PM
How many bulbs on Curvy Dash? hongman SV Talk, Tuning & Tweaking 8 09-08-12 09:09 PM
Dash bulbs - what and where from? Foamer SV Talk, Tuning & Tweaking 2 27-01-11 09:00 PM
sv650s curvy- what are the light bulbs behind the speedo/tacho? vzzzbuxt SV Talk, Tuning & Tweaking 2 19-09-07 04:48 PM
