#11 |
#12 |
Poss the wheel bearings gone? Have you recently had the rear wheel in or out?
#13 |
if the whole wheel moves then i would suspect that the inner spacer is missing and if so then its knackered the carrier bearing.
axle nut loose. if just the sprocket carrier is moving then i would suspect the carrier bearing is shot. very unlikely that 5 nuts have come loose unless some numpty has fitted a chain and sprocket kit then forgot to tighten the nuts. |
#14 |
As Bibio says; most likely carrier bearing.
Standard front sprocket, bigger rear sprocket, how many more links in chain required? | Holdup | Bikes - Talk & Issues | 6 | 27-02-12 12:40 PM |
Rough movement of rear brake pedal. | Chris Bird | Bikes - Talk & Issues | 9 | 13-08-11 01:00 PM |
Rear sprocket, which way? | DavieSV | SV Talk, Tuning & Tweaking | 0 | 12-05-08 10:40 PM |
REAR SPROCKET? | nikki_sv400s | SV Ecosse | 4 | 31-08-06 05:11 PM |
47T Rear Sprocket | bobit69 | SV Talk, Tuning & Tweaking | 39 | 26-03-06 10:53 AM |
