Old 10-02-13, 03:29 PM   #11
Well I am under way and thoroughly enjoying doing it myself.. and my ocd helps with keeping an eye on the bolts and clips .. a nice mornings work in the shed ..
Bit more cleaning then new chain and sprockets can go on .
Old 10-02-13, 03:30 PM   #12
Cant believe how much crud was in there.. might be part of my cleaning regime now to strip it down ..
Old 13-02-13, 08:08 PM   #13
So....
Here is my attempt at riveting new chain on ...
Is it ok ? .. burred over enough ?
Old 13-02-13, 08:12 PM   #14
Fallout
Fallout's Avatar
Default Re: chain and sprocket change?
Hard to tell from pics. If there's a visible mushrooming it won't come off. Check the link to make sure the o-rings don't look too different to the o-rings in the other links (i.e. not overly squished or not squished at all) and make sure the movement is as free as the other links. Then you're probably good. If it does look dodgy, then there's not much you can do now. Just keep an eye on it, unless it's the rivet that looks dodgy! Make sure that's good.
MotoGoLoco - You knows it
Fallout Breakbeat (My Music)
Old 13-02-13, 08:21 PM   #15
What Fallabout said.
Any even small distortion is enough to stop the plate coming off, the important factor is the position of the plate in that the 'O' rings will function correctly.
Old 13-02-13, 08:53 PM   #16
dyzio
dyzio's Avatar
Quiff,
What chain is that and what did you use for riveting?
Old 15-02-13, 08:29 PM   #17
Dyzio . Its just a did chain off e bay .. and a set off e bay for chain splitting and riveting .. not branded one .. can link u if u wanna see
Old 15-02-13, 09:48 PM   #18
dyzio
dyzio's Avatar
Nah, that's ok Quiff.
Thanks
Old 16-02-13, 10:30 AM   #19
Make sure you undo front sprocket nut before you grind old chain in half.
Old 16-02-13, 10:44 AM   #20
dyzio
dyzio's Avatar
Aye, I'll try to remember
Just wondering what would be good to use on a Tsubaki revit link as mine will need doing sooner rather than later. The whale tool Mark mentioned looks a bit pricey (£100+) or just go for the hammer method.
Standard front sprocket, bigger rear sprocket, how many more links in chain required? Holdup Bikes - Talk & Issues 6 27-02-12 12:40 PM
chain and sprocket change stephencassidy SV Talk, Tuning & Tweaking 17 05-09-09 03:18 PM
First Chain & Sprocket Change - Two Question! Steve_God SV Talk, Tuning & Tweaking 16 09-11-08 09:21 AM
Front sprocket change Fuzz SV Talk, Tuning & Tweaking 4 21-04-06 12:24 PM
Ok to change the sprocket at the 1st service? kevin1970 SV Talk, Tuning & Tweaking 3 29-08-05 04:58 PM
