Old 29-08-05, 03:50 PM   #1
kevin1970
Default Ok to change the sprocket at the 1st service?
Hi,
I am just coming up to the 1st service and looking for a few cheap upgrades/modifications.
I quite fancy changing the sprockets... do you think I could get away with just a sprocket swap, without changing the chain (will only have done 600 odd miles).
I am a bit on the heavy side, so I thought I would give the bike a fighting chance
SV650S K5. R&G Sliders.
Old 29-08-05, 03:59 PM   #2
Supervox
No more Mr Nice Guy
Supervox's Avatar
Default Re: Ok to change the sprocket at the 1st service?
Originally Posted by kevin1970
Hi,
Why do you want to change the sprockets after only 600 odd miles ?
The 'purists' will tell you that whenever you change sprockets you should change the chain as well - however, if you take a good look at it to make sure it's not hooked (unlikely after so few miles unless your wheelie maniac !!) then you should be ok
Never argue with an idiot - he'll drag you down to his level and then beat you with experience
Supervox is offline   Reply With Quote
Old 29-08-05, 04:23 PM   #3
kevin1970
Default Thanks for the reply:)
Just thought i would change the number of teeth, give the bike a bit more zip on the cheap
Old 29-08-05, 04:58 PM   #4
jonboy
Just change the rear as it's only 600 miles, an extra two teeth will be about right, and will give a little extra zip and also have the front wheel off the ground a fair bit when pulling away in first . There'll also be a few more vibes and you'll be forever trying to change up into seventh but it's perhaps the best and certainly the cheapest "performance" mod going and won't affect your insurance.
I've done it and glad I did.
First Chain & Sprocket Change - Two Question! Steve_God SV Talk, Tuning & Tweaking 16 09-11-08 09:21 AM
CBR600RR whilst SV in for service, should I change? SV'dd Bikes - Talk & Issues 60 14-11-07 12:53 PM
Service Manual for SV650S 2001 and Service Recommendation stone SV Talk, Tuning & Tweaking 1 09-05-07 04:20 PM
Front sprocket change Fuzz SV Talk, Tuning & Tweaking 4 21-04-06 12:24 PM
A Few Quick Q's (Oil change, Crash bungs & Sprocket Chan goof SV Talk, Tuning & Tweaking 8 19-06-05 10:00 PM
