#11 |
Picture was grabbed from sv rider site and looks like the spacer has been loosened and moved out as he had a snapped rear mount bolt doh! so your one is more than likely fine, but then again i am a mechtard
Black naked 1999 sv650 which im trying to keep happy Custom paintwork Saragon Customs Spray painting Electrical fault finding guide and Regulator rectifier test Only a biker knows why a dog sticks his head out of a car window. |
#12 | ||
So yeah, the spacer should be touching the engine, rather than floating as per the svrider picture which has no engine bolt in it ![]() Jambo
Modern motorcycles are bloody brilliant, enjoy it while we can ![]() Last edited by jambo; 30-05-13 at 01:00 PM. |
#13 |
The reason it's a threaded spacer in a clamp, is because it needs to be able to move laterally to suit the engine/frame specific fitting, they're not all in the same spot - hence some will fit nearly flush, some won't.
Missing bolt on new sv | SIII | SV Talk, Tuning & Tweaking | 13 | 18-02-11 08:10 PM |
Missing a bolt, | ScottishRawker | SV Talk, Tuning & Tweaking | 4 | 27-10-08 03:41 PM |
how to get the sump plug/bolt or filter bolt out without murdering someone? | Paul the 6th | Bikes - Talk & Issues | 11 | 31-05-08 10:49 AM |
Missing bolt! k7 sv650s | DavidSV650 | SV Talk, Tuning & Tweaking | 50 | 01-11-07 07:45 PM |
Rad mount bolt missing/dropped out? | Reckless Rat | SV Talk, Tuning & Tweaking | 2 | 11-07-05 01:30 PM |
