Old 24-06-13, 09:52 AM   #11
muzikill
muzikill's Avatar
Default Re: Camshafts - where from?
Were they starved of oil ?
Old 24-06-13, 03:56 PM   #12
Littlewebber
Yeah starved of oil, and everything fine except cam caps not the actual cams, the camps have gone slightly oval
Old 25-06-13, 07:24 AM   #13
They are part of the head AFAIK
Old 25-06-13, 07:33 AM   #14
Littlewebber
So u can buy the removable cam caps seperate?
Old 25-06-13, 07:34 AM   #15
I think the caps are part of the head. As in the head is made and then the camshaft journal is line bored as one piece. So the caps are not replaceable on their own.
If it's egg shaped the journal both halves of it will be stuffed anyway.
I am really surprised it hasn't knackered the big ends too.
Old 25-06-13, 07:35 AM   #16
http://www.robinsonsfoundry.co.uk/co...lheadfront.htm
No... see. Caps are not listed as discrete part. They are part of head.
Old 25-06-13, 02:12 PM   #17
Cam caps are line bored with the head and aren't replaceable.
Agree about big ends, if the oil pressure dropped low enough for the cams to be starved the crank definitely will have too.
Changing Camshafts Serdna SV Talk, Tuning & Tweaking 24 23-11-11 12:41 PM
Injected camshafts braders Stuff Wanted 5 01-11-11 08:54 PM
pointy camshafts ice For Sale - SV's and SV related items 1 10-12-10 08:28 AM
set of STD camshafts for a pointy.. please ice Stuff Wanted 5 25-09-10 07:46 PM
wanted intake camshafts green1 Stuff Wanted 0 04-06-09 06:59 PM
