Old 20-11-11, 03:51 PM   #1
Serdna
Default Changing Camshafts
Im going to be visiting a bike breakers yard in the next week to try and get hold of some Pointy intake cams for my Curvy. What i would like to know is what is a fair price for a set of used cams? And how much is a breakers going to ask me for? Plus anything to look out for on the camshafts themselves.
Thankyou!
Old 20-11-11, 04:32 PM   #2
squirrel_hunter
squirrel_hunter's Avatar
Default Re: Changing Camshafts
Which breakers are you going to out of interest?
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 20-11-11, 04:34 PM   #3
muzikill
muzikill's Avatar
Wont they be rusty as hell?... I remember when doing the pointy rebuild two of them dried out slightly and the rust spots were starting to show..... Dont get wrong i wouldnt buy them new but if someone can give some advice on how to spot a reasonable set and clean up advice it would be worth it.
Old 20-11-11, 04:37 PM   #4
Serdna
There is only one i know of and I'm going for the first time so I don't know what to expect. My mate calls it Oxford Bike Breakers, online I've found it under Royal Oak Farm.
http://www.autoinsider.co.uk/local/m...rs/ai_8923.php
Have you ever been?
Old 20-11-11, 04:39 PM   #5
Serdna
I don't know. So look for rust then. Is any rust a big no-no?
Old 20-11-11, 04:41 PM   #6
muzikill
muzikill's Avatar
Anyone?
Old 20-11-11, 05:42 PM   #7
squirrel_hunter
Don't know that company, was just wondering.
As for what to look for rust, scoring on the polished surfaces, bluing from heat. Anything that doesn't look like it came from the factory. As for price, the cheaper the better, can't remember what I paid for mine but search on here for previous asking prices in the for sale section.
Old 20-11-11, 06:18 PM   #8
devojunior
is there much noticable gains when fitting the injected model intake cams and is it a like for like item other than the obviouse duration and lift of the cam cheers adam.
Old 20-11-11, 08:02 PM   #9
Serdna
Info on the mod
Old 20-11-11, 09:50 PM   #10
4hp maybe. You can feel difference.
Markings are a little different as you're swapping between in and ex.
Pointy Intake Camshafts Serdna Stuff Wanted 0 17-11-11 11:39 AM
Injected camshafts braders Stuff Wanted 5 01-11-11 08:54 PM
pointy camshafts ice For Sale - SV's and SV related items 1 10-12-10 08:28 AM
set of STD camshafts for a pointy.. please ice Stuff Wanted 5 25-09-10 07:46 PM
wanted intake camshafts green1 Stuff Wanted 0 04-06-09 06:59 PM
