#11 | |
Kneel down beside it, lift it up, you can feel where "level" is because that is balanced. Observe oil level. 250ml in 1000 mile is nothing to worry about just top it up
#12 | |
Depending on how well everything that is supposed to be sealed is actually sealed, engines normally burn some oil, and sometimes leak some too. 250ml/1000 miles is good. If it gets up to a quart/1000 miles, you might want to think about corrective action, though of course obvious leaks should be fixed as soon as possible. And even at a quart/1000 miles, oil is cheap compared to an engine tear down and re-ringing. |
#13 |
Large Member
Listen to Yorkie_Chris
Only thing I can add is how do you ride the bike? If you caine it then chances are some of oil that has disappeared is in your air box. Just keep an eye on it
How to amuze an idiot: Look right-> <-Look Left |
#14 |
thanks for this posts. so take it that this is normal rather than a fault ?
#15 |
#16 | |
I check mine every time I get on it TBH, it's not hard to do once you get into the habit.
lost keys to my k3 sv650, what to do? | corsa120 | Bikes - Talk & Issues | 5 | 05-06-12 09:13 PM |
Is lost... | Grinch | Idle Banter | 33 | 22-10-09 04:05 PM |
Lost Electrical Power SV650 99 | philbert | SV Talk, Tuning & Tweaking | 4 | 26-05-09 12:15 PM |
I must be lost... | _Stretchie_ | Soho Massive | 18 | 24-05-07 02:53 PM |
