#11 |
Thanks for all of the advice, guys. I nipped down to Chasbikes in London on Saturday as they had a new OEM cable in stock and had a bash at installing it on Sunday.
Here's a wee snap of what I saw when the cable snapped. ![]() I guess this was just wear and tear? I cracked open the clutch cover and was greeted with this beauty... ![]() Loadsa beautiful muck in there... Definitely due a clean. The crud was almost half an inch thick at places. There is some oil near the chain here, which appears to be dripping from somewhere. I gave the worst areas a cursory wipe with the promise to do a proper clean next weekend once I've gotten some bits to do a good job with. I was thinking pressure washer, bristle pad, a couple of toothbrushes and some automotive detergent? I have no idea where the oil is coming from though. The cable itself was a doddle to fit (thanks for the tip on routing the cable by taping it to the end of the old one, Wideguy) and I greased the wotsits off of each end. The only griefy bit was prying that tab away to release the nipple at the clutch. I was terrified it was going to break off... My only concern is that the clutch lever feels really springy. I'm not sure what the technical term is, but when it's pulled in (which it does grandly) it's really eager to go back. I guess the only way I can describe it is that it feels perfect on the way in and like a hand grip on the way out. Is this just because it's a new cable or does it need more slack somewhere? Hell, this might even be normal and I've just ridden with a crap clutch all this time. I also did as you suggested, Pete, and changed my oil and filter. The old filter looked like it belonged in a museum! There were what I could only describe as barnacles on the filter head. The oil also looked like Coca Cola... Last edited by Mako; 15-07-13 at 09:20 AM. |
#12 | |
Once it's clean and dry you then stand a chance of locating the oil leak. Pete
It's official, the iconic naked curvy SV650 are now classics ![]() |
#13 |
Is it not just chain lube being flung off the front sprocket?
#14 |
I don't think so, I use this waxy stuff in a rattle can. I stand to be corrected once I give it a clean though!
#15 |
If your clutch cable is clean and lubed with motor oil as it's supposed to be, what you will feel is the clutch springs trying to re-engage the clutch. You probably didn't feel this before because your cable was dry and dirty and dragging in it's housing. Periodic oiling is required for clutch and throttle cables. If not, they drag, fray and eventually break.
#16 |
Don't pressure wash bikes!
You'll pressure wash all the water and crap straight into the chassis bearings.
#17 | |
#18 | |
Service intervals. | creamerybutter | SV Talk, Tuning & Tweaking | 17 | 14-10-14 01:07 PM |
Service Intervals | H | SV Talk, Tuning & Tweaking | 6 | 03-01-07 07:45 PM |
service intervals | tiggersv | SV Talk, Tuning & Tweaking | 1 | 26-03-06 01:38 PM |
Service Intervals | monkfish | SV Talk, Tuning & Tweaking | 3 | 09-11-05 05:55 PM |
service intervals | silent | SV Talk, Tuning & Tweaking | 3 | 07-06-05 08:43 PM |
