Old 22-07-13, 05:07 PM   #11
Default Re: LED indicators erratic flash rate.
Sounds like the resistors might be overheating. Working fine when cool then changing the flash rate as they heat up. Swapping the relay is always a better option
Old 31-07-13, 08:59 AM   #12
MarkB852
New LED compatible indicator relay arrived and duly fitted. Out of interest I tried the indicators before taking out the resistors and they all worked perfectly. No amount of twiddling of connectors and resistors could replicate the erratic flash rate problems I was having so it seems that the relay was the problem.
I was tempted to leave the resistors in for a passing moment but got over it and took them all out which meant that I got to use my lovely crimp tool where I had to change from male to female and vice versa.
I guess my advice would be to forget fitting resistors and go straight to the LED compatible indicator relay from the start. Makes for a prettier installation as well!
Thanks all,
Mark
Old 31-07-13, 09:19 AM   #13
NTECUK
NTECUK's Avatar
hope you didnt snag your tights or break a nail
Mark
Old 31-07-13, 12:45 PM   #14
MarkB852
Plays havoc with me acrylics!
Oh dear, oh dearie dear, oh dear. Lozzo Idle Banter 33 05-10-11 08:50 AM
Oh Dear Oh Dear...The problem with fitting a BMC Filter and rejetting is............. Dappa D SV Talk, Tuning & Tweaking 36 15-09-08 05:24 PM
oh dear oh dear - summertime Balky001 Bikes - Talk & Issues 53 27-06-08 01:53 PM
Remove front indicators space -Move indicators in headlights JanGoris SV Talk, Tuning & Tweaking 5 19-04-06 09:27 PM
gsxr 600 indicators and sv k5 indicators (put down - drop) swamp SV Talk, Tuning & Tweaking 3 03-04-05 02:25 PM
