Old 13-10-13, 04:30 PM   #11
MickeyHall
Default Re: Front end conversion
What part are you after?
Old 13-10-13, 05:45 PM   #12
JohnStMartin
I don't think it exists, its a plastic housing that the clocks from a pointy 'S' can go into when they are liberated from the nosecone.
i dont know if the S clocks would just lot into the naked housing here :
Old 13-10-13, 05:53 PM   #13
MickeyHall
Yes it would its the same clock, but I don't want to pay in excess off £150 for the separate parts.... Our clock ends at part 5 so you need the rest of the housing brackets and bolts.
Old 13-10-13, 05:55 PM   #14
JohnStMartin
Is that really the price? you could get a trailtech vapour + housing + indicator lights for £129 !!!
Old 13-10-13, 06:02 PM   #15
MickeyHall
The lower casing is £47 and the silver side is £36 the brackets are like £12-£19 each and the bolts and clips are £2-£3 a go, so that's roughly £130... The only problem with the vapor is setting the tachometer I believe, and the hassle of setting up all the independent sensors as the use their own
Old 13-10-13, 06:04 PM   #16
JohnStMartin
I had a vapor on a basket case i attempted to build in my youth. The tacho is just a wire you wrap around the HT lead, and everything else uses the original wiring, as far as i know..
Old 13-10-13, 06:04 PM   #17
JohnStMartin
vapour probably looks better to, in my opinion.
Old 13-10-13, 11:27 PM   #18
if your going to put a small fly screen on then no need for casing. just make sure you electrical grease up the connector.
GSX-R Front end conversion phil24_7 Photos 268 06-06-13 12:34 PM
My Front end conversion danf1234 SV Talk, Tuning & Tweaking 20 26-10-10 09:58 AM
GSXR front end conversion using SV front wheel maviczap SV Talk, Tuning & Tweaking 24 13-03-10 02:06 PM
SV GSXR front end conversion tiernanobrien SV Talk, Tuning & Tweaking 16 19-07-09 02:29 PM
Front end conversion Bikerz SV Talk, Tuning & Tweaking 5 28-05-05 06:45 PM
