#11 |
If you want a waterproof 12v socket, get one from towzatronics, pretty much everyone I know has used their sockets, I've had 3 of them on different bikes.
#12 | |
ah ok, sorry phil, I didn't realise this about other brands using different voltages etc. I just thought they were all the same no matter what, if you've got the connector thing that goes into what always would have been the cigarette lighter thing in a car. then I just thought it would be a general thing and used on all models. so in that case is my garmin going to require a 12v one?
AR08 to AR13-QUALITY! 650s: '52 curvy in yellow, was my baby ![]() cbr600rr: Mivv exhaust and a bagster tank cover. Now gone to a new home. Daytona 675: Arrow can (with a baffle that's gone missing in action.... ![]() ![]() |
#13 |
Would have thought the charger cable for the unit and the bits inside would sort itself out.
All cars are 12v output in the lighter socket so if any brand runs on anything different it would need to be sorted internally.
2011 Triumph Daytona 675, Arrow exhaust and QS! |
#14 | |
it says on the charger itself "INPUT:10-30V" does this mean it'll be needing the standard 12v then?
#15 |
Yeah that's fine then mate. All you need is the right socket to plug it in to.
I assume it is a normal cig lighter plug?
#16 |
yep it's a normal cig lighter plug as far as I can tell.
#17 |
I've got one on the SV. When you come out have a look at how it's wired in. If I managed it a Muppet like you will be able to do it.
Tender is the day, The demons go away, Lord I need to find, Someone who can heal my mind... |
#18 |
Here you go mate:
This is the main socket, it's got a rubber weather cap and the wires going in are sealed. It also has a mount built in with 2 holes for fitting: ![]() ![]() ![]() It's got spade connectors on a short pair of wires: ![]() ![]() And 2 individual lengths of wire for the positive and negative feed. The positive has an in line fuse near the battery end which has a circular connector: ![]() Unfortunately a well meaning but slightly ham fisted house mate managed to pull the circular connector off the negative wire when cleaning up: ![]()
#19 |
Yep, the official 12v plug chargers that come with the satnavs have step down transformers built in to the plug, never cut one off and try to hard wire in without checking the voltage the satnav receives.
#20 | |
Where to buy this connector? | djotanov | SV Talk, Tuning & Tweaking | 6 | 22-11-11 09:02 PM |
Volt regulator? | sandman | Thames Valley | 19 | 02-05-10 05:02 PM |
Advice installing 12 volt outlets | pale rider | SV Talk, Tuning & Tweaking | 5 | 31-07-09 06:49 AM |
SV sidelight connector | DarrenSV650S | SV Talk, Tuning & Tweaking | 2 | 04-07-07 10:47 PM |
Volt Meter Fitting | pablohoney | SV Talk, Tuning & Tweaking | 3 | 27-06-06 02:11 PM |
