#11 |
OK ORDERED:
DID 525 ZVM-X Gold 108 link chain Front JT sprocket (15) Read JT sprocket (44) Blue loctite DID KM500 rivet tool DID KM500r Pin for ZJ ZVM rivets thursday delivery ![]() total delivered just over £200 - ouch!!!!!!!!!!!!!!!!! |
#12 | |
#13 |
really???!!!! they gonna get all gunked up anyway
plus i'll just use loctite on them Last edited by nikon70; 22-04-14 at 08:59 PM. |
#14 |
The steel nuts usually end up corroded or worse. Stainless ones stay nice and shiny. Like this
http://i1252.photobucket.com/albums/...y/DSCN3786.jpg These were on my Hornet. |
#15 |
oh for reference (more mine)...
sprocket nuts to 60 N·m (6.0 kgf-m, 43.5 lb-ft). rear axle nut 100 N·m (10.0 kgf-m, 72.5 lb-ft). |
#16 | |
m10? |
#17 |
#18 |
i think is the difference between me having a new chain fitted this weekend or not......
#19 |
Shiny nuts and loctite? Wtf. Lol nuts off, change, back on and torque.... job done.
Sent from my GT-I9505 using Tapatalk
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
#20 |
lol
chain and sprocket change? | Quiff Wichard | Bikes - Talk & Issues | 23 | 11-04-13 10:22 AM |
Standard front sprocket, bigger rear sprocket, how many more links in chain required? | Holdup | Bikes - Talk & Issues | 6 | 27-02-12 12:40 PM |
chain and sprocket change | stephencassidy | SV Talk, Tuning & Tweaking | 17 | 05-09-09 03:18 PM |
First Chain & Sprocket Change - Two Question! | Steve_God | SV Talk, Tuning & Tweaking | 16 | 09-11-08 09:21 AM |
Ok to change the sprocket at the 1st service? | kevin1970 | SV Talk, Tuning & Tweaking | 3 | 29-08-05 04:58 PM |
