#11 |
FOC to you my friend. Just pay for postage. PM me your address and I'll get it posted, together with the Karcher lance that I promised someone else (I am so slack!!)
#12 |
Gota love such a friendly forum! Thank you very much
#13 |
Suprised that bolt was rounded due to the fact its stainless steel thats used for them.
Sent from my GT-I9505 using Tapatalk
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
#14 | |
I have been reliably advised by searching many threads on here that the bolts are in fact a rare substance called cheesium, not steel which is a lot more expensive as it needs to be crafted with the tears of virgin unicorns.
2011 Triumph Daytona 675, Arrow exhaust and QS! |
#15 |
Not the ones that hold the black infills on the frame tbh.
#16 |
Big thanks to ninthbike! Indicator received very promptly
#17 |
My pleasure.
#18 |
And a massive thanks to nobbylad bolts received
![]() Last edited by Niall_farley; 01-05-14 at 07:43 PM. |
#19 |
My pleasure.... nobbylad
#20 |
Indicator not working (Right indicator) | Randomdude | SV Talk, Tuning & Tweaking | 7 | 19-02-14 01:35 PM |
Fairing bolt / Mirror bolt | MiniMac | Stuff Wanted | 0 | 02-07-08 10:26 AM |
how to get the sump plug/bolt or filter bolt out without murdering someone? | Paul the 6th | Bikes - Talk & Issues | 11 | 31-05-08 10:49 AM |
Help me build a spare bolt box; what are all the common bolt | F16Falcon | SV Talk, Tuning & Tweaking | 10 | 07-05-07 08:42 AM |
Seat Bolt and bar end bolt | Colby | Stuff Wanted | 3 | 04-04-07 04:56 PM |
