#11 | |
You can find fault with any bike if you look hard enough. |
#12 |
Well, I test rode a street triple and loved the way it rode. Hated the transmission whine at low revs though. I queried with the dealer and he told me they all make that noise.
Some say the cup is half empty, while others say it is half full. However, both are wrong; the real problem is the cup is too big. Honda 125 CG blown engine Gone to the great mechanic in the sky Naked SV650 K3 in Silver |
#13 |
Told ya Britney! Was only a matter of time
![]() Reliability - Yes, they do all make that noise, doesnt mean the noise is a problem. I've been on Triumphs for the last 4-5 years and done a lot of miles, only issue I've had was a broken wire in the wiring loom, and had to replace a reg/rec, both of which can happen to any bike as they use the same wiring and the same company makes the reg/recs for loads of different manufacturers. |
#14 |
Think my reg/rec in goosed. Changed the stator few days ago and still not charging the battery. Groan...will have to wait until I get back from work before i can do anything about it now.
Still rode to Bedford and back for work a couple of times...can't believe how rusty I am...or scared...not sure which yet.
Smokey Black Burnty 02 - Racetech Smoulderlators + .90kg BBQ Springs, zx10r shockingly toasted, Conti Road Attacks heat up very nicely, R&G Crash Bungs but what f**king use are they, No Colour Matched Hugger, Flame Extenda, Beowulf Titainium Oval Flame Thrower. |
#15 |
Multimeter here if you need to test it Chris, bring the bike over one evening. I changed the reg/rec for a Shindingen Mosfet and I've never looked back solid 14.2v charging at any revs. You do need to bypass the wiring loom and wire the new reg/rec direct to the battery though using a heavier wire and 30 amp inline fuse, the OEM loom gets very hot once there's a decent reg/rec on the bike.
#16 |
Firstly; I can't believe anyone is shorter than you...
Secondly; I also have a trumpet now. Welcome to middle age Thirdly; I still want your trousers. Drop and cough |
#17 |
What year is it, Britney?
There was a recall for Street Triple reg/recs - check if yours was due one & if it was done HTH
Was: K2 naked in rapid yellow ![]() Now: Street Triple R |
#18 |
Ah it's all sorted now. Turned out to be the reg/rec. replaced it with a Yamaha R1 reg/Rec.
Doing weird things now though in that it won't start first time but after a few more times it starts fine and the speedo doesn't work but if I bump start it rolling up to lights it resets itself and the speedo starts working again. Weird little things! So now MOT'd. Looking to get out on it in the next few days as I've just booked a track day at Cadwell on the 17th to put it through its paces.
I'm getting back on 2 wheels! | Paul the 6th | Bikes - Talk & Issues | 41 | 29-11-11 04:13 PM |
Will my bro go back on two wheels? | timwilky | Idle Banter | 7 | 28-03-11 09:28 AM |
Back on two wheels.. | 454697819 | East Anglian Revolution | 40 | 14-12-10 11:58 AM |
Back on two wheels.. | 454697819 | Idle Banter | 0 | 27-10-10 12:32 PM |
Back On 2 Wheels | JakeRS | Bikes - Talk & Issues | 7 | 11-11-05 10:35 AM |
