Old 03-04-24, 12:46 PM   #11
redtrummy
Default Re: Fuel pump problem
Sounds awful rowdy - hope the outcome is positive. Stress can cause a lot of problems.
redtrummy is offline   Reply With Quote
Old 03-04-24, 01:37 PM   #12
rowdy
rowdy's Avatar
Yes it can. I have been to some very dark places over the last 6 months. Thanks guys.
Old 16-07-24, 10:54 AM   #13
rowdy
rowdy's Avatar
Quick update. Replaced the fuse, new battery and the fuel pump relay clicks when the ignition turned on. I took the fuel pump assembly apart and replaced the pump with a Kemso pump. Mate of mine owns a bike shop and recommended these as an alternative to paying £1233 for a new one from Suzuki.
Installed it and still nothing. Just taken it out again and went to local bike shop that tested it. Dead as a dodo
It’s a k3, has a white plug on the end of it. The later ones seem to have a brown plug. I’m going to have to try my luck with a second hand one, but does anyone know if these brown plugs are different or are they same connection, just different colour plug?
Old 17-07-24, 10:10 AM   #14
R1ffR4ff
R1ffR4ff's Avatar
I'm not really up on electric fuel pumps as my old 99 is basically vacuum assisted but if you get no joy I'd give a cheapy like this a go,
eBay SV650 Fuel pump,
Or there are YT videos on rebuilding your original that may help,
https://www.youtube.com/results?sear...mp+replacement
Old 18-07-24, 02:00 AM   #15
rowdy
rowdy's Avatar
That is basically what I got, although a slightly more expensive one as that is what I was advised to get.
Stripped and re assembled my fuel pump assembly with it but still nothing, was told by bike shop the whole assembly is probably farked.
Have got a complete second hand unit winging it’s way to me now, so hopefully that will resolve the issue.
Old 18-07-24, 09:23 AM   #16
R1ffR4ff
R1ffR4ff's Avatar
Hope it works out for you
Old 18-07-24, 04:05 PM   #17
rowdy
rowdy's Avatar
It did. Fuel pump arrived earlier on so fitted it and we now have life in the old girl. Needs a bit of fettling, doesn’t like to idle and it’s a bit lumpy so new spark plugs needed, and I had the fork seals replaced and have ridden about 20 miles since they were done and now have fork oil running down the left hand tube ��
Old 18-07-24, 04:17 PM   #18
R1ffR4ff
R1ffR4ff's Avatar
I did my fork seals a while ago and always use 15w fork oil. I use Smith and Allen oils,
https://www.smithandallan.com/produc...k-oil-15w-4114
https://www.smithandallan.com/produc...cycle-oil-4116
I only use ,"All Balls" fork seals on 2nd hand Motorcycles. I've never had one fail yet. They have an extra seal skirt to help prevent leaks.
All Balls Fork seals eBay
and this should be useful as I do my own,
https://www.youtube.com/watch?v=vrmYJgcGX30&t=1276s
http://www.bluepoof.com/motorcycles/howto/svs_fork_oil/
and for the plugs,
https://straticus.epizy.com/SV650SparkPlugsCaps.html
2008 SV650 Fuel Cap/Fuel Pump jwray4422 SV Talk, Tuning & Tweaking 3 26-06-18 06:27 PM
Starting problem-fuel pump not purging DJ123 Bikes - Talk & Issues 6 09-08-11 09:28 PM
New fuel pump. problem found muzikill SV Talk, Tuning & Tweaking 2 19-05-11 09:32 PM
Fuel pump problem, maybe. mudgutsdunn SV Talk, Tuning & Tweaking 5 11-03-10 11:54 PM
Fuel Pump Problem hindle8907 Bikes - Talk & Issues 2 29-11-09 01:34 PM
