#11 |
Did my rebound holes (not that Ive noticed any difference) with solder. Countersunk the outside a little and then made a blob on the end of a bit of solder wire. Fed this through the hole from the inside and melted the bit sticking out to fill the hole. Worked a treat...
#12 | |||
Junior Member
As for progress, got the hole for the Oil Sensor welded up so I need to drill and tap that, then it's off to the powdercoaters ![]() |
#13 |
Would sealing with a pop rivet work?
#14 |
Its possible but not sure about possibility of protruding head contacting something - see attached...
#15 |
Junior Member
keep trying to reply but apparently a moderator has to review and approve it :/
#16 |
John T
Sorry I didn't spot the prompt to approve. Now done.
#17 |
Normally its enough to slacken the bottom bolt with the fork still on the bike but obviously axle removed. The force of the spring inside should hold the damper tight and the same for retightening when finished....
#18 | |
Junior Member
#19 |
I used a woodworkers sash clamp to compress each leg in turn,this increasing the pressure insidethebleg, allowing the bolt to undo
#20 |
Junior Member
I'd forgotten how much parts cost these days, just spent £80 on bearings for the swingarm and suspension knuckle thing.
Filed off all the flashing (?) on the handlebars and sent a load off to the powdercoaters, swingarm etc. |
Sv 650 project for somebody maybe? | Booka | For Sale - SV's and SV related items | 6 | 21-04-15 05:21 AM |
My new project | mister c | Photos | 121 | 06-07-12 02:54 PM |
help with uni project | TeddyBearKing | Idle Banter | 20 | 17-04-09 06:33 PM |
gpx project | Airwolf | SV Talk, Tuning & Tweaking | 1 | 19-08-08 08:49 PM |
What 'project' for £100 | glade | Bikes - Talk & Issues | 20 | 24-10-06 07:19 PM |
