Old 26-01-05, 01:56 PM   #11
M65
Originally Posted by jonboy
I can certainly downshift without the clutch and still blip the throttle, you've just got to be ultra-precise. Is there any point to it? Not really 'though it's handy when I'm on the mobile...
Just going off at a complete tangent, I once got called on the mobile while I was in the car driving home and was asked if I was on the bike or not
Old 26-01-05, 02:14 PM   #12
pegasus
pegasus's Avatar
tune in, turn on, burn out
pegasus is offline   Reply With Quote
Old 26-01-05, 03:12 PM   #13
zx6man
Think my zx6r manual says not to down shift without clutch as it will cause mechanical problems with the transmission....will check it tonight
Old 26-01-05, 03:18 PM   #14
steveo
Going the opposite way - clutchless upshifts. I tried this a few weeks ago and it wouldn't change, the lever just felt solid. Do you have to be really caning it to do?
Old 26-01-05, 03:20 PM   #15
zx6man
revs tend to have to be quite high for smoothness, on my anyways
Old 26-01-05, 03:28 PM   #16
wyrdness
Clutchless upshifting is usually only an advantage if you are caning it and want to change up that bit quicker. I usually ease of the throttle, kick the lever and back on the throttle again, all as quickly as possible.
Old 26-01-05, 03:29 PM   #17
steveo
Hmm, ok, maybe i need a little more commitment to the cause!
And yeah i realise where the advantages lie, i just thought i would try it a bit lower down the rev range to start off with as i don't know what would happen etc. As it happened all that occurred was some fairly hard engine braking!
Old 26-01-05, 03:54 PM   #18
BURNER
I only clutchless downshift when I'm riding with a broken clutch cable.
Hasn't happened yet on the SV.Touches wood!!
Old 26-01-05, 04:18 PM   #19
Jabba
Actually, you might need less committment, if you get my drift......
If you're accelerating hard then you might need to easy off the gas a bit to take the "strain" out the transmission and match the revs to the next higher gear.
Try putting pressure on the pedal and then easing off the gas a tad - should snick in nicely, then back on the gas.
In my (admittedly limited) experience, one needs to do both and it's a matter of timing.
Old 26-01-05, 04:24 PM   #20
steveo
I was shutting off the gas completely before trying to shift gear which may be where i was going wrong. May try it on the way home as the weather and roads seem ok even though its a little cold.
Incidentally i was behind a Hornet with twin akraprovic pipes this morning, sounded lovely
So does doing clutchless changes muck up your box? petevtwin650 SV Talk, Tuning & Tweaking 30 05-06-10 11:16 PM
Clutchless gear changes Larry SV Talk, Tuning & Tweaking 13 12-04-07 02:35 AM
Clutchless upshifting Stu Bikes - Talk & Issues 23 23-08-06 01:27 PM
Clutchless changes ThEGr33k SV Talk, Tuning & Tweaking 1 21-08-06 10:37 PM
Clutchless Gear Changes? sweepdoggydog Bikes - Talk & Issues 21 16-08-05 03:14 PM
