#11 |
blip blip blip
and then i get that awesome backfiring/induction noise ![]() |
#12 |
just bang it down and let her slip.... what you worrying about ? its not going to make u fall off!!! just dont go down the gear box as hard if you dont want it to slide
#13 |
I find if you've got a standard pipe fitted you have more engine braking, fit a less restrictive pipe, blip that throttle and enjoy.
#14 | |
#15 | ||
![]() I've got a slipper clutch ![]() ![]() You can either learn to blip the throttle on downshifts or be a little bit smoother with letting the clutch out. Learning to blip the throttle on downshifts is a good skill to learn on it's own. It can come in if you need to loose a bit of speed on a dodgy surface where using the brakes might be just that little bit risky. Cheers Ben |
#16 |
Thanks all for your comments, it would seem that I need to master the throttle blip - gentle clutch thing
![]() 21QUEST, do you have a slipper clutch on an SV or are we talking a different bike here? Jenni, I've only been caught out in the rain once and I rode so slowly there was no chance of a rear wheel lock up! My old Yamaha was so slow to respond to throtle changes it was actually quite easy to ride in the wet, whereas the SV gave the feeling that if I opened or closed the throttle to quickly it would not hesitate in dumping me on the road for my foolishness. |
#17 | |
#18 | |
1. Suzuki SV650 OEM Anvil 2. Suzuki GSX-R Anvil 3. No brand ironmongers anvil i wasnt sure if it was worth the extra money to upgrade to a GSX-R anvil, especially as i dont generally ride that fast... i didnt think i could use the 'uprated' anvil to its full potential on my commute. the SV anvil comes in cheaper and from the looks of it will do the job for road use. however, just before i plumped for the purchase i came across an old anvil that a blacksmith had been using in a barn, he let me have a go and it worked a treat!!! whats more he gave it me at a snip of the price of a Suzuki one!!!! im thinking about getting a GSX-R one for track day use. Hope this helps. |
#19 |
The Sick Man
I find that if you need to realy hard brake, not to worry about the rear because it is probably going to lift a bit and then lock up anyway.
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
#20 | |
Engine Breaking? Hopefully not. Engine braking - is that OK? | butterick99 | SV Talk, Tuning & Tweaking | 14 | 12-09-09 10:31 PM |
Engine braking... any hazzards engine wise? | John 675 | SV Talk, Tuning & Tweaking | 21 | 28-03-08 07:20 PM |
Engine Brake - Wheel Lock | danf1234 | SV Talk, Tuning & Tweaking | 23 | 29-04-07 11:59 AM |
engine braking on the sv! | kwak zzr | SV Talk, Tuning & Tweaking | 11 | 25-04-06 12:01 PM |
Braking an engine | svrash | For Sale - SV's and SV related items | 1 | 22-03-06 10:43 AM |
