#11 |
Advice given by somebody who really should know.
http://forums.sv650.org/viewtopic.ph...njector#356709 I won't bother adding to it because I'll get it wrong then I'll have the Evil Dr being sarcastic at me (again) ![]() |
#12 |
Whether you decide the dual injector works as stated or not, I believe it it easier to fit than the standard tubing on certain models, as the supplied bracket is really easy to adjust and fit. I had terrible trouble with the single injector, it kept moving about and would need repositioning when the chain was tightened. I have had 1000% less hassle with the dual injector, and I will buy one for every Scottoiler kit I may purchase in the future. Call me stupid, naive, whatever. It works for me and I'm more than happy with the product.
#13 | |
True in the case of the SV this does invlove a small mod to the Scottoiler bracket, but if you're contemplating fitting the oiler yourself I doubt it's outside your likely capabilities.
#14 |
#15 |
*Grinds teeth*
But the plates don't need to be oiled.
#16 | |
#17 |
I have just fitted a dual injector. Mainly cause if done neatly it looks neater than the single, and i think that it is easier to adjust and get it right.
Works for me and i am happy |
#18 |
Oops I meant the inner roller/plate interface thingummy youknowhatImean. Anyway, The chain is now oily on both sides, and the sprocket is well lubed too.
Jon. |
Injector flow | wojto | Bikes - Talk & Issues | 0 | 26-01-08 09:05 AM |
fuel injector size? | wildwestsydney | SV Talk, Tuning & Tweaking | 1 | 14-02-07 11:07 AM |
Mk7 Scottoiler and dual injector | Dodgy | For Sale - SV's and SV related items | 5 | 02-11-06 06:15 PM |
Finally ordered a scot oiler | MavUK | SV Talk, Tuning & Tweaking | 15 | 22-07-05 08:50 AM |
Scottoiler Injector positioning.... | Nekkid | Bikes - Talk & Issues | 15 | 22-03-05 08:20 PM |
