Old 25-03-06, 02:52 PM   #11
MrMessy
Default Handlebar conversion:
Hi,
I fitted the LSL conversion to my 99S. You need a longer front brake line from the master cylinder to the splitter and a longer clutch cable. I kept the original clutch cable, but it eventually snapped due to the routing of it. I had to move some of the cables to the outside of the fork legs to get them to fit.
MrMessy is offline   Reply With Quote
Old 25-03-06, 09:55 PM   #12
admin
John T
admin's Avatar
I do have risers on my curvy SV.
see the 2005 section of this http://www.sv650.org/sv_restorer.htm
I have a spare oversize brake hose, the top bit you can have for nought.
John
Old 26-07-09, 09:44 PM   #13
alanmmccarthy
Default Re: Riser bars on the SV650S (curvy)
Mine is 1999 models - quite an easy mod to do - use top yolk off naked version - switchgear all fits
BIGGEST RENTHAL STREETFIGHTER BARS FROM BANDITMANIA FITTED- (massive rise)
Banditmania do them with switchgear holes already pre drilled for extra couple of quid - I have put naked top-yolk (25 QUID E BAY) on mine - all cables do fit but need careful re-routing - longer front brakehose fitted (just got a complete front set cheap off off e bay and used the one of the splitter to lower fork hoses in place of master cylinder to splitter) - - I have double bubble screen fitted which has been modded/cut out (really easy) - had to use chewys mirror extentions as all you can see is you elbows without this mod (you could make your own I guess) - the whole shooting match was in the region of £100 - happy to send you a pic of mine if required
Alan
Old 26-07-09, 10:28 PM   #14
alanmmccarthy
http://sv650s.yolasite.com/sv650s.php
Handlebars with risers and renthal streetfighter bars fitted from banditmania
Raising the bars on an SV650s - possible? GaryP SV Talk, Tuning & Tweaking 21 04-08-09 07:35 AM
Fitting high bars to an SV650S lairylarry SV Talk, Tuning & Tweaking 6 27-07-09 08:46 PM
Renthal bars on a curvy ? Nicky S SV Talk, Tuning & Tweaking 8 08-03-09 10:57 PM
Cheap riser for SV650s Bars?? svscratcha SV Talk, Tuning & Tweaking 6 20-08-07 05:33 PM
SV650S bars for SV650 bars? MikeC SV Talk, Tuning & Tweaking 11 08-12-06 12:34 PM
