Old 21-03-06, 10:57 PM   #11
G - renamed
I've got the clutch cover off and all looks ok around there.
Haven't properly got the water pump off yet, but doesn't look like it came from there.
Old 22-03-06, 01:47 AM   #12
kaned1
Just pull your valve covers off before going any farther. There are two freeze plugs in each cyl. head as stated in the last thread. That is your most likely cause of that much coolant in the oil that rapidly, especially in two bikes without coolant.
You can put the plugs back in with green loctite, but you may have to pull the covers off the sides of the engine to find the plugs if they in fact are popped. They tend to fall down the cam chain area on either side of the engine.
Old 22-03-06, 01:00 PM   #13
G - renamed
Cheers, exactly the problem.
Anyone know where the last thread about it is?
Did search a fair bit, but couldn't find 'owt.
Old 22-03-06, 04:24 PM   #14
SV650Racer
yes this happened to my old K3 race bike. Easy to fix and next time store over winter with anti freeze in the bike.
Old 22-03-06, 04:37 PM   #15
jonboy
Why don't racers use anti-freeze?
Old 22-03-06, 04:40 PM   #16
Carsick
Cos it's slippery and a bugger to clean off the track.
They user water wetter or something similar to keep the anti-corrosion properties.
Old 22-03-06, 04:43 PM   #17
Biker Biggles
Biker Biggles's Avatar
So it does'nt get spilt on the track in crashes.I don't know if it's harder to clean up than oil.
Old 22-03-06, 04:43 PM   #18
SV650Racer
Water wetter isnt allowed either.
Old 22-03-06, 04:47 PM   #19
Carsick
Fair enough. Does anything get used at all or do you just keep changing the coolant between races to prevent corrosion?
Old 22-03-06, 04:59 PM   #20
SV650Racer
No coolant!. Its just distilled water and it stays in the system all season..no problemo!.
petrol contamination riktherider SV Talk, Tuning & Tweaking 8 22-01-09 05:33 PM
Important contamination warning!!! Spanner Man Idle Banter 3 25-10-07 11:30 PM
Coolant help therealvw SV Talk, Tuning & Tweaking 3 07-08-07 08:02 PM
Sorry -coolant again tomjones2 SV Talk, Tuning & Tweaking 6 17-06-06 09:47 AM
Fuel contamination Ping Bikes - Talk & Issues 6 11-08-05 07:49 AM
