Old 29-03-06, 08:36 PM   #11
etrevinosv
I too have the same problem. Mine was performing the same way I thought it was the oil so I changed it out and I put 3 quarts in (sorry for units) and now it won't start it turns though. I think the reason it was running weird was because it got water in the front spark plug. but it still isn't running any suggestions?
Old 29-03-06, 08:46 PM   #12
after my 600mile oil change i went back to my dealer and said it had'nt got enuf oil in, they told me they run the sv's slightly below half on the sight glass.
Old 29-03-06, 08:50 PM   #13
etrevinosv
so if my oil is full when i hold it up does that mean that i should take some out? but it would still start right?
Old 29-03-06, 09:15 PM   #14
its just what the dealer told me prob being tight with there oil
Old 29-03-06, 09:31 PM   #15
etrevinosv
so no pointers on why it isn't startin up? the bike has started right before I did the change so the only thing is that it isn't enough or too much
Old 29-03-06, 10:01 PM   #16
socommk23
if everything wont start...ie lights too then its electrical!
Old 29-03-06, 10:02 PM   #17
etrevinosv
the engine turns and then lights are on
Old 29-03-06, 10:06 PM   #18
socommk23
bike upright! check oil level is in tolerance! if noy empty some out!
take plugs out and give it a quick turn over! this will show you if any oil has got in!
if so it will clear most out
clean plugs and maybe some carb cleaner needed! should do it i think!
ooo..is it a cab model?
Old 29-03-06, 10:30 PM   #19
etrevinosv
so you think it is the too much oil that is built the pressure up to high or that it has gotten in the plugs?
Old 29-03-06, 10:51 PM   #20
socommk23
give it a go!
dont cost anything and will rule it out!
let us know yeah!
Oops Stu Soho Massive 19 03-03-09 06:34 PM
OOps. Jester666 Soho Massive 2 03-07-07 12:34 PM
oops weazelz Photos 14 23-03-07 11:08 PM
Oops wyrdness Idle Banter 6 03-09-06 02:05 PM
