#11 |
There is a repair paste you can get,made bty the same people who make 'Chemical Metal' it it good,BUT I've only used it on REALLY small holes.
Maybe worth a try if you can't get it repaired. ![]() |
#12 | |
#13 |
I had a zxr tank opened & re welded back together when the internal breather pipe broke .
Got a classic bike mag & through a contact found in them got a new breather pipe fitted to tank . They opened tank & re -welded for 30 quid ! Sorry don't have the number for the welder . Then again don't know how much a 2nd hand tank for a sv is , if they are cheap then go for one . Second hand tanks for a zxr were rare , paid 130 quid for one & guess what the breather pipe was knackered , got refund & had the original tank fixed . Good luck getting it fixed Cheers Steve
ex - red sv650s 06 reg Now Triumph sprint 1050 ABS 05 Reg AKA Papa Smurf ![]() |
#14 |
Thinking of trying this
![]() Anybody used it before? |
#15 | |||
#16 |
I have just spent half hour collecting and pouring petrol from my tank to a bowl........
Same problem..... Noticed some crap down the side of my bike on Sunday.... Thought it was just a bit of bird crap... Anyhow.... Went out, filled the tank... Got home two hours later. thought.......oooooh, strong petrol smell. Thought nothing of it till next morning when I found petrol... Hmm, not good I thought. Anyhow. tonight i thought I would have a look, so I did..... Lifted the tank, and the petrol started to flow... and then it got bigger and bigger as parts of the tank started to fall off!!!!!!! Now I have a hole around half the size of a 1pence piece!!!!! Can't belive it............... You are not alone................ What I want to know, is what caused it??? It's in a well protected place, and mine contrary to yours is on the right side, away from the lean!!!!!! Red Tank (99 also) needed .................. Splosh... |
#17 |
Well splosh bad luck but at least im not alone!
A bloke at work welded my tank today and did a pretty good job of it. great i thought and i couldnt wait to get home and test it but after a few seconds of waiting the b*****d thing still leaks ![]() I am now thinking about something called Kreem that you put inside the tank and it recoats the inside. But i think with the size of the hole in your tank it would be hopeless. Going to the bike shop tomorrow to see what they suggest and to price up a new tank. How did you drain yours? i ended up taking the fuel tap off mine. As to what caused it, well apart from a production fault it can only be water collecting on the bottom of the tank , its weird that yours is on the right hand side though. |
#18 |
After countless attempts to fix the tank with leak fix i have given up and ordered a new tank.
Every time i fixed a leak in one place it would leak from another, splosh, mine also had a hole in the right side of the tank like yours. Why this has happened can only be down to sitting water in the tank but on a 7 year old bike i think it is still crap. I also have a 1957 BSA bantam and that tank has never leaked!! For anybody who has the same problem a new tank is £239.20 plus vat. I did consider buying one off ebay but the only one available was a blue one and the paint bloke wanted £150 to spray it the correct colour. Also i thought that maybe a similar age tank might have the same problem. Getting it done next week so at least i will be able to go on the annual rideout! |
#19 |
i had a kawa tank welded years ago. It gave me a lot of problems, as i was going to yugoslavia after. The bike kept breaking down.
it turned out that it had rust in the tank which was clogging up the fuel tap/ system. used a number of in line fuel filters to complete the trip after cleaning the tank. if you have rust its worth having a fuel filter fitted. |
#20 | ||
leaking petrol. | simonthepost | SV Talk, Tuning & Tweaking | 2 | 10-05-09 07:31 PM |
clunks every now and then, petrol overflow leaking | piers | SV Talk, Tuning & Tweaking | 4 | 30-04-09 09:44 PM |
Leaking Petrol | Stevetmanchester | SV Talk, Tuning & Tweaking | 7 | 31-05-08 05:18 PM |
Leaking petrol after a drop | ranathari | SV Talk, Tuning & Tweaking | 5 | 28-04-08 05:58 PM |
Leaking petrol cap | jonny-zero | SV Talk, Tuning & Tweaking | 10 | 30-04-07 08:04 PM |
