Old 27-12-06, 04:10 PM   #11
RandyO
Originally Posted by wheelnut
Originally Posted by RandyO
recommended pressures are for cold tires
But what is a cold tyre?
A cold tyre in Tangiers might be 20degree C and in Glesga a cold tyre could be -5'c
cold tire temp is the temp on tires that haven't been warmed up on any given day by riding on them
don't worry about ambient temperature
when tires are warmed up, they increase pressure by 4-6psi
Old 27-12-06, 06:50 PM   #12
ejohnh
You cannot ignore ambient temperature because tyre pressure varies with it. A 17C difference in ambient temperature gives a 2psi (approx) diff in pre-warmup pressure. Probably splitting hairs if you are content to be 2psi out on your running pressure.
Happy New Year
John
Old 27-12-06, 08:27 PM   #13
Alpinestarhero
cold being around 15-20 degrees. Thats cold enough from optimum operating temp of 60-70 degrees!
Matt
Old 27-12-06, 11:36 PM   #14
ejohnh
Matt
you are studying chemistry?
I studied applied heat. 15-20C approximates to 60-70F, the rest is what? Are you saying that tyres get up to 70C? If so I am amazed.
JohnH
Old 28-12-06, 06:42 PM   #15
RandyO
Happy New Year
John
yes, IGNORE ambient temperture
what ever temperature it is when you start to ride, check your pressure before you ride, if the pressure doesn't meet recommended cold pressure, raise or lower it accordingly, regardless of temperature
Old 28-12-06, 08:13 PM   #16
ejohnh
Default what temp is a warm tyre? :o)
Does anyone know what temp a tyre achieves when it is warmed up? Is it fairly constant?
Old 28-12-06, 08:49 PM   #17
RandyO
Default Re: what temp is a warm tyre? :o)
40°F-60°F above ambient temperature,
Tyre Pressure evilexel SV Talk, Tuning & Tweaking 5 20-02-09 10:57 PM
SV650 Tyre Pressure krhall SV Talk, Tuning & Tweaking 12 13-11-07 12:21 PM
How much?(tyre pressure) Jussi Tyres 4 26-07-07 08:07 AM
What's your tyre pressure? Diveboy SV Talk, Tuning & Tweaking 28 03-05-06 07:05 PM
Tyre pressure? Rodger Wabbit SV Talk, Tuning & Tweaking 10 24-11-04 12:23 AM
