#11 |
I've just realised its a 3/16" hole you need, you won't be able to drill it in one go, you'll need a smaller pilot hole, 1/16" if possible then enlarge it with 1/8", then 3/16", its starting to sound more expensive for one tiny little hole ! If you have a variable speed drill try it at low speed with lubricant. Once the drill's blunt you're wasting your time, engineers sharpen their HSS drills on a grinding wheel before using them, the precise angle ground into the cutting tip of the drill must be exactly right or it won't cut.
#12 | |
#13 |
You need to start off with a smaller drill bit and then go up to the size you need also you need to use some cutting compound to stop the drill bit over heating.
#14 |
#15 |
Trinity
If you want a plug in drill just let me know. Probably not great for bits though,
#16 | |
#17 |
Update: Did it!!
![]() Went out and got an automatic centre punch which made the smallest indent ever in the pipe. Also went out and got a 4.5mm (slightly too small) hss titanium bit which actually went through the pipe like a hot knife. And I got the rivet to fit eventually. Thanks P.S. I needed to drill a hole in the pipe just under the footpeg where the link pipe joins on. The hole is for a securing rivet that goes through the link pipe and into the exhaust downpipe. I guess it's a Yoshimura thing. |
#18 |
Also, a lot of cordless drills will have serious issues cutting steel- I wouldn't even bother with mine, that's what the ancient Bosch is for (it's nearly as old as me)
Cut exhaust pipe | adoh30 | Bikes - Talk & Issues | 10 | 12-08-08 06:46 PM |
exhaust pipe | 01 sv650s | SV Talk, Tuning & Tweaking | 7 | 26-11-06 12:42 AM |
exhaust pipe | oldie | SV Talk, Tuning & Tweaking | 0 | 30-08-06 08:58 PM |
exhaust pipe | oldie | Stuff Wanted | 0 | 29-08-06 02:35 PM |
SV650S - Exhaust pipe | Stupidbash | SV Talk, Tuning & Tweaking | 3 | 27-01-05 07:48 PM |
