#11 |
Little tip. Wrap a couple of zip ties around your fork legs, slide them down to the bottom and go out for a ride. Try not to use the front brake, especially aggresively and see how much travel your forks are using. Might give you a guide.
#12 | |
#13 |
Hmm, lots of food for thought. The thing that confuses me is that up in the Gwaun valley yesterday some of the roads are so tight that I was literally coasting at 20mph, along a bumpy road. It was really uncomfortable. I will try the zip tie when the rain stops, then play with the pre-load. Thanks again
#14 | |
#15 |
#16 |
I'd say you should definately use the front brake, and hard at that. After all, what point is a nice ride over bumps if it'll spit you off the moment you apply the brake, cos you ran out of travel?
#17 | |
Edit: I know what you're saying and the bonus of adjustable suspension is it gives you greater range of control, but if the bike's preload is set about right and bottoming out as soon as you touch the brakes it may be that the spring rate's too low.
Modern motorcycles are bloody brilliant, enjoy it while we can ![]() Last edited by jambo; 24-04-07 at 03:59 PM. |
#18 |
Braking should NOT use all available travel (unless doing a stoppy I guess). You still need some left to deal with bumps while braking. I tought this was the whole point of getting the spring rate matched to your weight and setting preload to give correct amount of sag? i.e. enough spare travel to cope with the loads thrown at it.
#19 |
See, it's interesting, cos I've got the emulators, 20 wt oil and 90 springs and using the brakes uses all my travel, about 120mm, but without using the brakes the travel is around 70mm. Still trying to get mine to handle as well as my previous one did with only hyperpros and oil,
#20 | |
Suspension advice pointy. | ScottishRawker | SV Talk, Tuning & Tweaking | 10 | 24-04-08 12:21 AM |
Suspension overhaul Advice welcome | Jackie_Black | SV Talk, Tuning & Tweaking | 0 | 16-03-08 09:20 PM |
Need advice on front suspension | FishyMug | SV Talk, Tuning & Tweaking | 9 | 05-07-07 09:28 AM |
Naked Curvy with GSXR Suspension Adjustment Queries | Ter | SV Talk, Tuning & Tweaking | 3 | 08-09-06 05:39 PM |
Help - need advice on suspension settings | monkfish | SV Talk, Tuning & Tweaking | 2 | 12-11-05 07:42 PM |
