Old 17-04-08, 11:18 AM   #11
ljharmitt
Default Re: Replace broken gear lever?
They can be annoying, dizzyblondes yellow bike was a pig for this, the levers were so stiff, I ended up using the big hammer method.
Tried the big hammer method didnt work so ended up using hot water to expand it, straight out
Old 19-04-08, 12:27 PM   #12
thinman
turns out something disconnected in the clutch so they were able to fix it easily. Back on the road and waiting for a dry day to ride!
Old 29-07-09, 10:38 AM   #13
danco1
Exclamation Re: Replace broken gear lever?
Did you have much of a problem repairing or replacing your left front turn signal? I have one broken off now and am seeking guidance on how to replace or repair. I think it must have broken off while I was pulling off a rather substantial fabric bike cover from my 2002 SV650S.
Thanks!
Old 30-07-09, 08:57 AM   #14
thinman
yea if I remember correctly it was a dodle. Take the fairing off, disconnect old wires and then feed through the hole in the fairing and connect.
Old 19-10-12, 10:21 PM   #15
Paul Locker
My clutch lever broke off tonight when the side stand was not fully extended by myself!!!! What a %%%% I am...broke my front left indicator too...gear lever bent!!! Just a lapse of concentration!!!Costly!!!!!
How to straighten a bent gear lever? (heat it up first? or what?), ---possible fix or recipe for snapped of gear lever :-) martin_SV SV Talk, Tuning & Tweaking 10 30-07-08 08:40 PM
K5 Pointy 650S right hand wing mirror, gear lever and clutch lever. Bayside GTR Stuff Wanted 0 29-10-07 11:24 PM
2 left indicators + clutch lever + gear lever for pointy k6 enduroman Stuff Wanted 3 06-09-07 09:26 PM
A broken Gear change lever (Mk1SV) Viney Stuff Wanted 2 19-07-07 02:04 PM
Broken Gear Lever ***Steve*** Bikes - Talk & Issues 11 04-06-06 10:43 PM
