#11 | |
Also, I'd question the notion of the Z6 being a "cheap" tyre, either in terms of performance or cost. As bikerbiggles says, the problem is all due to the tyre tread pattern. I was actually once on an IAM test when I the problem reared its head. I pointed out to the examiner when he asked about it in the car park at the end that he had looked at the tyres before the start of the test and due to the tread pattern, they had appeared still legal, in spite of being almost completely worn out. |
#12 |
I really don't understand the problem to be honest... Roadtecs don't have tread in the middle, but you can tell at a glance at the tread nearest the middle when you're running out of tyre. The wear bars can't possibly tell you what wear is like across the tyre, on any tyre, and to expect them to is frankly a bit daft... There's a difference between "legal" and "worn out".
You should replace a tyre before it's completely worn out, doing otherwise is like using wet feet as your sign that it's time to go to the toilet.
#13 |
Yep my strada went rapidly down hill this weekend, and I noticed on my way up to Durness, the most north-westerley village on mainland Scotland, there was no tyre place there either... It looked way fine in the morning then about 300 miles later as I took a photo I realised it had v.litle left.
Found somewhere with a tyre that'd fit the SV about 80 miles away the next morning, pretty lucky. |
#14 | |
As an aside, for some reason, with z6s on my bike, they always wear out exactly the same way- front tyre on the side (tread is worn slick on the sides and stepped in the middle) and back tyre in the middle (on the slick bit). It's almost as if the hard centre banding on the front could be a bit softer. |
#15 |
Are stradas two compound tyres too then?
#16 | |
#17 | |
http://www.tst-tyres.co.uk/images/RoadtecZ6R.jpg |
#18 |
This was my Z6 on my SV1000 after I returned from last year's North/South.
Before I left home, I checked the tyre and it looked fine - there were no cracks in it. The tread was looking low, however there appeared to be around 2mm on the tyre wear indicators - I was more than confident that they would last the trip. Around 900 miles and a puncture later (600 motorways/main roads and 300 hooning around North Yorks/Cumbria) they looked absolutely fecked - cracks and gouges out of them all the way round ![]()
2000 - 2004 SV650S 2004 - 2009 SV1000S 2009 - 2013 Triumph Sprint ST1050 2013 - 2016 Triumph Explorer 1200 2016 - Ducati Multistrada DVT S ![]() |
#19 |
I know, I've worn out 2 rear Roadtecs... And in both cases, the tread right by the middle was very obviously worn down. I did run one until it delaminated, because I wanted to see how long it'd take. I've seen quite a few with delamination in various sizes caused by overuse, and they were all the same- obviously ridden on past their normal lifespan.
"Legal" isn't the same as "not worn out" like I say. I've got a completely legal, completely square Macadam out the back, it'd probably be good for a few thousand more miles but it'd be rubbish to ride on- worn out. Equally, I've got an illegal Pilot Race which I could use on the road for another thousand without the slightest risk. Both have plants growing in them. The law on tyre depth isn't intended to tell you when to replace them. It's an absolute minimum which has to be left incredibly vague, so as to cover all tyres, and it's there to deal with people who choose not to replace their tyresw when they're worn out... But it doesn't follow that an illegal tyre is unsafe, or that a legal tyre is safe. Remember, that law varies from country to country, if you take a bald tyre to america where it may be legal it's not suddenly any better at dispersing puddles. Metzeler, like most tyre companies, recommend that you replace any tyre with less than 2mm of tread- from everything I've seen the Roadtecs will be under that before they do their sudden death trick. Mine certainly was when I pushed it, and both of those pics are too. Ah hah, a picture! Courtesy of MattSV, amazing what you find on google ![]() ![]() Here's another off a Fazer forum: And here's a Diablo doing the same: ![]() Now, all four are obviously worn out, from the delamination. But the tread beside the slick section tells the story, in all cases the rider's ignored the fact that the tread's worn right down. In fact, I think in all cases the rider claimed "I had plenty of tread left" ![]() Certainly none have 2mm of tread across the whole tread.
#20 |
Just the man. Even without the cracks, that tyre's very obviously completely worn out, just look at the tread! It's worn to practically nothing. The TWIs are on the shoulders, how can they tell you anything about the wear in the centre?
Chain wearing through swingarm. | manicmonkey | SV Talk, Tuning & Tweaking | 7 | 31-07-08 06:53 PM |
So, is it too late to suddenly decide to go to the NW200? | northwind | Idle Banter | 8 | 11-05-08 06:45 PM |
can you whistle when wearing your helmet? | hovis | Idle Banter | 7 | 16-09-07 04:57 PM |
Wearing a dress | Law | Idle Banter | 82 | 14-12-06 02:44 PM |
Clutch suddenly stiff | leatherpatches | SV Talk, Tuning & Tweaking | 5 | 09-03-05 10:30 PM |
