Old 25-10-07, 06:50 PM   #11
Demonz
Default Re: Google maps - how?
Try this Stu: http://forums.sv650.org/showthread.php?t=95581
Old 26-10-07, 09:52 AM   #12
Stu
Trinity
Stu's Avatar
Originally Posted by Gmonsta View Post
Thanks, read that but it still doesn't let you save google's route instructions.
Old 26-10-07, 10:22 AM   #13
Sosha
Can you screen capture and save as a text doc? or cut and paste? (I can also save the map but not the text)
Old 26-10-07, 01:05 PM   #14
Pedro68
I think you have to be logged into Google (using a Gmail account) to have the kinda functionality you want (but I could be wrong?!)
I've just tried it and I can only "name" a route if I'm logged in.
HTH,
Pete
Old 26-10-07, 01:57 PM   #15
Stu
Trinity
Stu's Avatar
yup logged in. I use Gmail, so not a problem to log in. Still doesn't work, but thanks anyway
Old 29-10-07, 02:25 PM   #16
Baph
OK, Stu, apologies for the delay:
1). Login to Google. (mail address in bold along the top of the screen).
2). Get your directions (for example, search "leeds to london" (without quotes) and get the directions on screen).
3). Click "My Maps" on the tabs on the left.
4). Click "Create a new map" just below the "search" tab. Note, this map is "Untitled," which is ticked, and the directions are still visible on the map, just no text is there on the left.
5). Give it a name, and a description if you like. Without a name, you can't save it!
6). Alter the blue directions line to your taste (I dragged from Rotherham over to Scun-t-horpe - no idea why). This changes you back to the search tab.
7). Go back to "My maps" and choose a different map (if you have a different map there - I do ).
. Go back to the map you just made a minute ago - it's still there, with all the details you put in manually. So long as you kept saving it whenever you see the "Save" button active. When it's not active, changes are saved auto-magically.
If you want to get written directions at any point, instead of the "My maps" dialog on the left, simply drag the route a little - even if it doesn't actually change.
HTH
Note to TSM: The language filter doesn't like S****horpe, not a big deal, not many people do!
Google Maps Motorcycle Parking Maps alexs Soho Massive 1 01-04-09 09:22 AM
Google Maps. How accurate? petevtwin650 Idle Banter 1 17-03-08 12:45 PM
Google Maps Blue_SV650S Idle Banter 13 24-04-07 07:33 PM
Google launches My Maps Baph Idle Banter 10 11-04-07 05:51 PM
