03-11-08, 04:49 PM | #21 |
Re: Heated Grips?
J&S Accessories sell the old analogue version of "Oxford HotGrips" but under the name "DR BIKE". £34.99.
Just bought a set cos my left grip died. Gives me a spare controller too, as I am on my second controller in 3yrs. I only have mine on halfway but thats with non-winter gloves and a low speed-ish commute. Burny hot-hot. Same wiring between old and new? Junk the digi and fit the DR BIKE analogue controller? Not heard anybody say anything good about those new digi ones. |
03-11-08, 04:52 PM | #22 |
Re: Heated Grips?
03-11-08, 04:54 PM | #23 |
Re: Heated Grips?
No they are not.
03-11-08, 04:55 PM | #24 |
Re: Heated Grips?
03-11-08, 04:55 PM | #25 | |
Re: Heated Grips?
03-11-08, 04:57 PM | #26 |
Re: Heated Grips?
I thought it was the battery going flat, but when I get home I plug the bike in to the optimate and it goes straight to 'maintain' rather then charge the battery. So I'll get round to soldering a new one at some point.
03-11-08, 04:59 PM | #27 |
Re: Heated Grips?
03-11-08, 04:59 PM | #28 |
Re: Heated Grips?
As long as you keep your lights off, I ride in the dark, so lights win over heated grips.
03-11-08, 05:01 PM | #29 |
Re: Heated Grips?
The new digi ones are fine if
a) you wire them up like the instructions say so and b) the electrics on your bike are in good working order. They are designed to shut down if the bike is not running (voltage drops to c12v) or if other devices are dropping the voltage down through excessive load (higher power lights, heated underpants etc). This is a good thing as it saves having to wire them through a ignition switched realy for those of us who forget to turn stuff off. However this is a bad thing if you have heated underpants or sub-optimal electrics. Other problem with the new ones is it's a lot more difficult to operate it if you can't see it. On my old curvy I had the old controller fitted down by the expansion container for the coolent. Out of the way but if you wanted to turn on or adjust while going along you could just fumble around down there until you found the button that made things warmer (now where have I heard that before ) this is a lot harder to do with push-button one so you either have to mount it where you can see it or remember to set unit up before you set-off and accept you're going to have to pull over each time you want to adjust it AND you have to turn it on again each time you get off to go for a pee or bacon butty (now where have I heard that before). I've burned out 1 old style one and no new fangled ones to-date.
Don't want to be the quickest; don't want to be the best; just want to be the one having the most fun. XL125Varadero -> Curvy SV650N-Y -> SV1000N-K3 -> Multistrada 1200s Twin-tastic stuff. Minister for Sustainability Aliquid prudentissimus delectabiles et intelligentes in adamasset lingua. |
03-11-08, 05:10 PM | #30 | |
Re: Heated Grips?
I'm thinking my problems is due to duffy battery, but I'll find that out this weekend when I stick it on an optimate and let my dad test the charging circuit YC hasnt ruled out goosed battery either on my bike. Im hoping thats all it is |
Heated grips | Daywalker | Bikes - Talk & Issues | 3 | 17-02-09 01:08 PM |
heated grips | zsv650 | Bikes - Talk & Issues | 6 | 08-12-08 11:48 AM |
Heated grips | skint | Bikes - Talk & Issues | 19 | 06-01-07 10:09 PM |
getting heated grips off -more help please!! | jenni | SV Talk, Tuning & Tweaking | 21 | 07-12-06 05:53 PM |
Heated grips | jimbobule | Idle Banter | 3 | 09-01-70 09:04 AM |
