Old 23-11-07, 01:12 AM   #21
Default Re: Brighter Bulbs What are the ones?
Originally Posted by Sean_C View Post
I'm going to get some Osram Nightbreakers over the weekend, just checking that the curvy sv uses H4 fitments?
H4 is correctamundo
Also welcome
Old 23-11-07, 01:38 AM   #22
walkaboutandy
Hi Sean C, welcome.
UK SV's are H4, euro SV's use H1 as they have one light that does main beam and one that does dipped with a magnifing lens. Does anyone know why Suzuki did this? Which is better?
I've been told that Bosch don't make the parts for retrofits like this, if that's true then this one'd be fake. It looks like the exact same ballasts as were included in mine, and those were random unbranded. Not to say it's not good stuff even if it is fake, mind
I would be interested to know how you get on fitting the kit and if its any good.
Old 23-11-07, 12:35 PM   #23
Sean_C
Thanks for the replies
My svs, if you're looking at it from the front, the right bulb is dipped, and then the left is main beam, which sounds like the euro sv? Mine is from Taz, not the first owner, but the original owner got it from Taz too, so it could well be a parallel import.
Sorry for noobish questions, but I'm a noob Had my license 4 weeks and my bike for 3.. restricted unfortunately, but I absolutely love it, apart from the headlights
Old 23-11-07, 02:09 PM   #24
You can replace the headlight and sub loom quite easily if you want proper lights
Old 23-11-07, 05:36 PM   #25
drefraser
I thought about pinching the big laser from work then I remembered it works at 1068 nanometers so I still wouldn't be able to see where I was going. And I'd need a really long extension cable. And it would destroy stuff in front of the bike.
Back to the carrots.
Old 25-11-07, 05:30 PM   #26
Just did a very rough install of my HID kit, not mounted the ballasts or anything, just to make sure it works and get a first impression. Said first impression is way better than I'd expected, the amount of light is quite amazing compared to even the night breakers and there's few visible hot and cold spots. It's throwing a little too high and to the right, but I'm going to try and sort that using the alignment (but right now I have an avalanche of wires making that impossible!) The overall beam seems wider, which is about the worst thing so far, but that may not be an issue. Ran them for about 15 minutes with fire extinguisher in hand. No fires.
More comments once I get it ridable, which may not be tonight, I can't really be bothered with all the nadgery stuff right now But it's certainly promising.
Old 25-11-07, 11:11 PM   #27
Tomorrow it is then. I got sidetracked Trying to find a place to mount hte ballasts, I found the perfect location on the front subframe, but there was a bit of frame in the way. Wonder what that does? I thought. Took front off bike to find out. It does nothing. Out with angle grinder, lop off quarter of a kilo of steel. Hmm, quite rusty. Out with wire brush disc, remove all the rust, spray with epoxy. And rest.
So, right now I have no headlights at all. Or fairing. Or clocks for that matter Par for the course really.
Old 25-11-07, 11:14 PM   #28
No fairing?
It's improving
Old 25-11-07, 11:18 PM   #29
It looks brilliant actually... It'd have planted a seed in my mind, if that seed hadn't already been planted about 2 years ago
Old 26-11-07, 08:31 AM   #30
Viney
The X-treme bulbs are half price from Busters.
head light getting brighter larigos SV Talk, Tuning & Tweaking 1 18-01-09 02:10 PM
Why do my lights get brighter when I rev the engine? thor SV Talk, Tuning & Tweaking 53 17-01-09 10:12 AM
Brighter Bulbs k146 SV Talk, Tuning & Tweaking 31 22-08-07 04:59 PM
Brighter Lights echomadman SV Talk, Tuning & Tweaking 14 13-04-05 06:41 AM
Brighter Headlight Installation... MitchC SV Talk, Tuning & Tweaking 15 14-03-05 08:55 PM
