Old 31-10-08, 12:11 PM   #21
coldtyres
Default Re: scraping footpegs through the corners
I am trying to improve my riding, hence the track days and I guess my riding is getting better in some ways . Even with what I know is bad technique but I am struggling to know what is the best and cheapest thing to do to stop that confidence sapping peg scraping.
coldtyres is offline   Reply With Quote
Old 31-10-08, 12:28 PM   #22
G
Position your toes right at the edge of the pegs, but slightly over hanging.......that way your toes will touch down before your pegs.....give you an inch or so but its an extra bit of confidence.....then you need to start sticking your knee out to guage much in the same way that your doing with the toes.
Helps if you have toe sliders or doing it to much can damage your botts obviously.
In the picture below the toes are right near the end of the peg, so would touch down before the peg itself.....much safer in my opinion.
6.67300 × 10-11 m3 kg-1 s-2
Old 31-10-08, 12:34 PM   #23
coldtyres
yeah thats a good tip i will definitely try covering the peg with my toe next time. Thats why i like this forum lots of different experience and advice. Cheers
Old 31-10-08, 01:48 PM   #24
SVStu
I'm no expert but have just replaced the rear shock on my 99 bike made a world of difference. A soggy shock could add to the problem I'd have thought.
Old 31-10-08, 02:27 PM   #25
coldtyres
definitely she is a 30000 mile never been touched shock. what did you replace it with?
Old 31-10-08, 03:31 PM   #26
custard
a piece elastic
Old 31-10-08, 03:49 PM   #27
johnnyrod
johnnyrod's Avatar
Good pic G. My rear shock gave up at about 150-20k miles without excess abuse. A stock replacement is better than adead one, but if you spin more for a proper one, or even go the ZX6R replacement route it's even better. I noticed with the stock one on the track you do get noticeable wallow, so that may be part of the story, but I agree with comments above, you need to get moving. I recommend the Superbike School www.superbikeschool.co.uk which is expensive but they'll set you right, guaranteed.
Old 31-10-08, 03:58 PM   #28
ThEGr33k
Get the rear end jacked up a little... Can do it with dog bones or a better adjustable rear shock. That should help a little I should think.
Old 31-10-08, 04:15 PM   #29
Berlin
Just found the perfect article for you. Bike magazine, September issue page 76.
before you start buying expensive bits and pieces. read this. Its about hanging off and scraping pegs.
C
Old 31-10-08, 04:19 PM   #30
About 12 stone you say?
SRAD 750 shock, quite a bit taller, more ground clearance and far better damped. Make sure front has right weight springs and oil in it first though, a tall rear shock will put the stock springs nearly to full compression.
Front wheel - scraping noise monkeydispenser SV Talk, Tuning & Tweaking 6 14-07-08 09:47 PM
Peg Scraping! Need more clearance! dmracing SV Talk, Tuning & Tweaking 13 22-08-07 03:15 PM
Scraping the bottom of the barrel jonboy Idle Banter 8 05-05-06 04:05 PM
Hugger scraping the wheel? carty Bikes - Talk & Issues 1 12-04-06 01:59 PM
pads and discs scraping rob13 SV Talk, Tuning & Tweaking 9 09-02-06 06:42 PM
