#21 | |
Steve |
#22 | |
Steve |
#23 |
#24 |
I have a non-standard double bubble and haven't checked it with the stock item so can't say how clearance is with it. I did take a small amount off the "ears", maybe 20mm or so just to ensure good clearance.
The FJ bars are steel forgings for the uprights with steel pipes fitted. The uprights needed some grinding at the rear side as you see them in the photo to clear the top yoke, still plenty of strength there. I welded a small pad on with drilled and tapped hole for the brake reservoir, drilled holes for the switchgear location pips, and added some tabs to accept the anti-rotation bolts into the underside of the yoke though it's not really necessary. Brake hose is about 25mm longer than stock I think, but everything else reaches fine. As I said, if you're happy doing this sort of fitting work it's not a big deal, otherwise pay the extra and get something already engineered for the job.
#25 |
hello again the awesome org,fitted my helibars at w/end however on the end weight front there is a plate in the end of the bars which will not allow the refitting of the oem weights,just a different screw to fit the weights on the end ,is this the way helibars are
![]() any advice thanks in advance |
#26 |
@ Bibio, nice bars you got there but i couldnt help but notice a rather sexy pic of a silver pointy with the rear end dismantled in your imageshack piccys
i finally finished puttin it back together lol ![]() Amp |
#27 | |
Actually I've got a pair that I'm thinking of selling (for a pointy), will probably flog 'em on ebay when I've finished by front end conversion |
#28 |
My bar ends went straight on the Heli's with the original Suzuki screws, no problems! What's the actuall issue you are having?
D |
#29 | |
i havent ridden since i put them on btw |
#30 |
It is the weights that remove the vibration, the rubber bung holds them in.
I take it you have them fitted, screwed in like a Curvy's are? |
Thinking of a new lid. | Grinch | Helmets | 28 | 23-01-09 07:45 PM |
thinking about and SV | orac | SV Talk, Tuning & Tweaking | 10 | 25-09-08 06:53 PM |
What were they thinking? | gettin2dizzy | Idle Banter | 0 | 29-03-08 02:35 PM |
Anyone thinking of getting a new 'tat? | Blue_SV650S | Idle Banter | 10 | 24-02-08 04:55 PM |
thinking about getting one | bankstontype-sh | Bikes - Talk & Issues | 14 | 05-09-06 03:23 PM |
